-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulating a Vinyl Garage Door (http://www.diychatroom.com/f103/insulating-vinyl-garage-door-165822/)
06Honda 12-07-2012 08:04 AM
I have a vinyl type product garage door. 4 panels that are straight open and across, 9 feet long and 16 inches wide with no edges to tuck in any blanket type insulation similar to what is in the Owens Corning Kit. I came across a product at my local home depot called "Reflectix".
1. Would this product work for my door?
2. If it will help warm up the garage a bit should I leave a pocket of air behind or attach it directly against the door and secure with the tape they also sell at home depot for this product?
Thanks for any tips? I can take a pic if necessary.
Paul
joecaption 12-07-2012 08:17 AM
I just use 1" blue foam attached with constrution adhesive made just for foam.
06Honda 12-07-2012 04:27 PM
Update:
I ended up using a product today called "Ayr-Foil", fairly easy installation with an air pocket on each panel. Way brighter in the garage thats for sure. May take a day or so to see if the temp is warmer.
Gary in WA 12-07-2012 07:59 PM
Check with your local AHJ, blue foam board requires covering for fire-stopping, the foil-faced may not. Though it may require positive fastening, other than adhesive.
Gary
