Insulating Under Roof Balcony - Insulation - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 09:23 AM   #1
Hi,
I've scoured the internet for answers and have come back more confused than when I started. Does any one know if there is a way to properly insulate under a flat-roof balcony without tearing off the ceiling of the living space below. The plan for the finished surface is EPDM with a deck on sleepers.
I've read articles that say you can either lay rigid foam on top of the deck or spray closed cell foam under the deck, but that requires add $$ and drywall mess. The way the door opens onto the balcony, I can't afford to add 2" of height with the XPS.
So my question is, is there a hybrid approach? Since the decking is torn off I have access from above. So I was thinking of putting Roxul down against the drywall then filling approx 2-3" of rigid XPS to the tops of the joists and air sealing. Like the following link, but only instead of spray foam I'd carefully place rigid. http://www.buildingscience.com/docum...ented_flat.jpg
Any thoughts?
Insulating Under Roof Balcony-img_8346.jpg   Insulating Under Roof Balcony-img_8349.jpg
tomdor is offline   Reply With Quote
Old 07-26-2013, 10:23 PM   #2
Registered User
Rewards Points: 5,516
Just be sure to foamboard the rims and make it all air-tight, no holes in drywall; http://www.buildingscience.com/docum...wall-approach/
R-10 and cavity batt fill to prevent condensation; http://www.buildingscience.com/docum...rchterm=attic+
Gary
Insulating options for flat roof marco529 Insulation 2 12-05-2011 03:57 PM
Insulating a shed roof? bmanley Insulation 1 11-03-2011 02:13 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Insulating a Garage Roof savaytse66 Roofing/Siding 7 01-04-2011 11:43 AM
Insulating under part of my Flat Roof Hushpuppy Roofing/Siding 5 02-13-2006 02:45 PM
