Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 02-08-2013, 12:15 PM   #1
Smile
Insulating under floor old home
I would greatly appreciate any advice for my situation.
Background:
* House built in 1904, located in Spokane, WA.
* Basement, two floors, and attic loft.
* Bottom floor is much cooler than second floor; in the winter when (basement) furnace makes bottom floor comfortable, 2nd floor is way too hot.
* Bottom floor (above basement) is made of only two layers of wood, each installed in a different direction. I would guess that some colder basement air may leak through the cracks in between the wood planks.
* Basement has thick old stone and concrete walls (part of foundation of home; there is no wood in basement walls). It has gas furnace, and does not have moisture problems.
* Basement ceiling is low (about 6'), and has wood joists 16" apart, about 6" deep.
Now, my questions:
1) If I put insulation up in the basement ceiling, would that possibly help warm up the rooms above? (If so, this could save on my heating bills and also make the temperature between 1st and 2nd floors in winter more even).
2) If I did put insulation, should I use faced or unfaced?
3) Would you suggest R19?
Thanks so much for any advice!!
Last edited by amosnliz; 02-08-2013 at 12:42 PM. Reason: To clarify my location and explain more about basement walls
amosnliz is offline   Reply With Quote
Old 02-08-2013, 12:23 PM   #2
Good back and add your location to your profile for better ansewers and less questions.
Have the outside walls been fire blocked yet?
http://sfsafetraining.com/BalloonFraming.pdf
amosnliz (02-08-2013)
Old 02-11-2013, 11:16 PM   #3
Moderator
http://www.advancedenergy.org/buildi...l%20Spaces.pdf
Wet foundation rocks; http://www.buildingscience.com/docum...e-toil-trouble
You are on page #56; http://www.energy.wsu.edu/Documents/...ers%201-10.pdf
Check with local AHJ.
Gary (across the mountains)
Clothes taking longer to dry?
Tags
basement ceiling, insulation, under flooring
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General Discussion 24 05-19-2011 08:23 PM
Insulating Interior/Exterior Wall Cavity? Old Home from Attic HandyFrank Building & Construction 3 02-07-2011 11:49 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
