If he was a building inspector with a county/city, he should have also mentioned the R-value required for your specific area.
"In Zones 1 through 3, open cell (vapor permeable) foam can be used successfully to enclose building spaces with moderate or dry interior humidities. In higher interior humidity spaces, closed cell foam or other roof designs are recommended." Taken from; see/read about Fig. 8:
http://www.buildingscience.com/docum...on?full_view=1
Without having the added cavity insulation, your situation is slightly different than these test results;
http://www.buildingscience.com/docum...d-roof-systems
Before I explain further, where are you located? Nearest large city...
What is the humidity reading in the room most of the year?
Gary
Clothes taking longer to dry?
