Insulating The Steam Pipes - Insulation - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 06:25 AM   #1
insulating the steam pipes
hello. i have steam pipe lines in my apartment. i have insulated the MS pipes with glass wool. I am thinking that if i use any gas insulation (say Chlorine gas insulation) i will be able to save energy as gases have very low thermal conductivity. Is it safe to use chlorine insulation.? What will it averagely cost for insulating 1 meter of pipe.? What if there is a pitting in pipe and chlorine gas enters the steam flow? Is using gas insulation advisable.?
neomech2012 is offline   Reply With Quote
Old 01-31-2012, 06:56 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Not sure I even know what you are talking about.
Can you provide some more details on it?
The reality is that insulating steam pipes that are used for heat that are inside building envelope do very little in terms of efficiency.
I would use standard insulation.
Old 01-31-2012, 10:37 AM   #3
Registered User
Rewards Points: 526
I would leave it all alone as you are not the owner. If you added something to the building and problems arose, you would be liable unless you had written approval from your landlord.
Gary
Steam Pipe insulation. Any gain for insulating return pipes? slowjo HVAC 17 02-19-2012 08:53 AM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 05:31 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
Insulating Steam Pipes Densec General DIY Discussions 4 10-06-2009 10:42 AM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 09:14 PM
