Insulating A Soffit.. - Insulation - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:11 PM   #1
valcarmo72's Avatar
Insulating a soffit..
My home was a Cape that was made into a custom colonial. If u look at the pic attached u can see the old soffit that was once the roof of the cape just above the existing windows.... Now, there obvioulsy a floor above it. I have the coldest floors on my second floor. Always wondered why. I was changing recessed lighting trim and while doing so I felt a strong current of air riding the cieling of the first floor. The back of the house has no soffit that low. Only above at the roofs edge. My question is...if the first floor soffits were originally there for proper ventilation for a roofs rafters, what purpose do they serve now? And can I insulate it of it is causing a draft or if current make my second floor subfloor cold as heck? The room just above the garage all the way to the left is the coldest but the garage has insulated cielings. Laser thermometer says the cieling is 65 degrees and the garage temp is 45 degrees...my thought is there is a draft causing the floor above the cieling to.be colder...Also, is there supposed to be such a strong current of air between first and second floors?....Thanks for the help..
Don't know?...ask someone...
valcarmo72 is offline   Reply With Quote
Old 02-27-2013, 10:55 PM   #2
747
registered
747's Avatar
Rewards Points: 534
Rooms above garages are always cold unless spray foamed. Ceiling in garage would need to be dropped and then spray foamed. You do have a point on lower soffits. i would just insult them now. Seeing how it now has a second floor addition and the roof is above it.
Ps. Nice looking house.
747 is offline   Reply With Quote
Old 02-27-2013, 11:05 PM   #3
valcarmo72's Avatar
Thanks really appreciate the help and the compliment. U know I really would love spray foam the cielings in the garage. I wish there was a way to keep out the drafts from a garage door but there really isn't. Thanks again.
Old 03-01-2013, 05:29 PM   #4
Registered User
Rewards Points: 5,212
The other option is f.b. under new 5/8" Type X drywall; fig.7;http://www.buildingscience.com/docum...n-crawlspaces/
Pull all soffit, foamboard/canned foam the floor joist, air-seal all openings into house- caulk/foam the rim joist; top/bottom, replace soffit material. http://www.engr.psu.edu/phrc/trainin...ngbarriers.pdf
http://www.conservationtechnology.co...issionPathways
Fig. 3; http://www.buildingscience.com/docum...d-but-strange/
Check your garage door weatherstripping and closer bottom flashing; http://www.homedepot.com/p/t/1001879...9#.UTEsblKsnAU
http://www.homedepot.com/p/t/1001254...7#.UTEsklKsnAV
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
valcarmo72 (03-01-2013)
Insulating soffit overhang? Mperez1202 Building & Construction 17 12-24-2012 11:24 PM
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 10:48 AM
Replacing soffit tucked behind brick veneer. Queequeg152 Building & Construction 3 02-25-2012 08:10 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
