Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-25-2012, 01:27 PM   #1
Insulating a small steel shed - cost effectively = Help?
I have an 8' x 7' steel shed for my Ebike with electric heater that needs to be insulated. What is the best cheepest solution?
fredrick is offline   Reply With Quote
Old 08-25-2012, 02:35 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Fiber glass bats; held in place with battens, wire, or chicken wire, secured to whatever is the equivalent of studs, joists, and or rafters. Depending on how thick the bat, you may have to furr out those studs, use spacers behind battens, or bend the wire back at sides of bats.
Batten the hatches, there's furry bats in the shed!!!
notmrjohn is offline   Reply With Quote
Old 08-25-2012, 02:57 PM   #3
Metal sheds are prone to condinsation, using batts would be a sure way to have mold.
I'd use foam panels with constrution adhesive made just for foam.
concretemasonry (08-25-2012)
Old 08-25-2012, 04:39 PM   #4
Bombastic Idiot
notmrjohn's Avatar
My mistake, i shoulda sed vapor barrier wrapped bats, with barrier to inside, edges taped, just like in commercial metal buildings, usually held in place with chicken wire, which is usually wired to holes that are usually already in the frame. Did I mention that all that is usually the way? No cutting of panels to fit between 'studs.'
But closed cell foam is good choice, it is its own vapor barrier. It's got to be glued directly to the wall, not to anything that would leave an air space behind it to collect that condensation. And this is an electrically heated, insulated shed, how much condensation will there be on the inside walls? Inside condensation happens when warm, moist air hits a cold surface. Condensation on window panes but not on insulated walls. And check the fire rating on what ever you choose. Some foam burns, some doesn't but gives of noxious even deadly fumes. Fiber glass doesn't burn, but some bats (cellulose, re-cycled paper) have to be covered with fire resistant hard surface ( sheet rock) some have a fire rated aluminum vapor barrier.
Old 08-27-2012, 08:55 AM   #5
PoleCat's Avatar
2" 4X8 white styrofoam boards are fairly cheap right now @ Home Depot.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
fredrick (08-27-2012)
Old 08-28-2012, 06:50 PM   #6
In a little over my head
Like notmrjohn said, check the fire rating. Lots of insulation types specify that they must be covered, can't be left exposed. The last fiberglass batts I installed said so clearly on the paper. I'd think some types of foam would be the same.
ratherbefishing is offline   Reply With Quote
Old 08-29-2012, 07:10 AM   #7
Not the cheapest solution, but spray foam would probably be the quickest.
As noted, some insulation must be covered. But I wouldn't worry too much about fire ratings in a small metal shed.
Old 08-31-2012, 01:41 PM   #8
Bombastic Idiot
notmrjohn's Avatar
Originally Posted by md2lgyk View Post
... I wouldn't worry too much about fire ratings in a small metal shed.
Neither would I, but.... homeowner and Ebike insurance Co.'s sez, "Woulda been covered, if not for insulation." Ebike- $600, 1000, 3000?
fred, contact a builder's supply house ( possibly big box) about 4X8 foil backed insulation board. R value of, I think, 3. glue it up, cover seams and holes in skin with foil duct tape, not duck tape, real duct tape. For price and ease of installation that's prob. "best." I don't think it is officially fire rated without covering but foil is added layer of protection as well as vapor barrier. And that electric heater is securely fastened in position with adequate ventilation around it too, right?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
Old 09-01-2012, 09:16 AM   #9
Perhaps. But I suspect the dedudictable on the OP's homeowner's insurance is more than what an Ebike costs. I know mine is.
Old 09-01-2012, 10:15 AM   #10
Bombastic Idiot
notmrjohn's Avatar
? So its OK if he loses his Ebike? Electric heater out there, might as well be safe as it is just as easy and not much more in cash outlay.
Hmm, electric heater...fred, say you're not running that off an extension cord.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Metal Shed Insulating Zen_Dog General Discussion 10 08-22-2008 10:30 AM
Cost of small addition on Long Island??? sonvolt10@aol.com Remodeling 1 08-08-2008 11:47 PM
Estimated materials cost for a shed? Jeekinz Building & Construction 18 12-13-2007 03:14 PM
Cost per square foot -- very small addition rubeng Building & Construction 7 12-13-2007 01:41 AM
