Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 03-19-2011, 08:14 PM   #1
Insulating Sill Plate
Moved into older home, the sill plate has white foam board right now. Looking to insulate this year. The actual sill plate does not cover the top of the block completely, maybe half of it. We have the cavity of the blocks to contend with. What is the best way to insulate this? Should we liquid nail another board on top of the block then insulate or can we spray foam the cavity of the block as well?
garyc is offline   Reply With Quote
Old 03-19-2011, 09:48 PM   #2
Windows & Remodeling
HomeSealed's Avatar
There are cheaper ways, but spray foam is phenomenal in this application.
HomeSealed is offline   Reply With Quote
Old 03-21-2011, 09:52 AM   #3
Are you saying its ok to fill the holes in the top of the concrete blocks with the foam?
If we don't use the foam what would you suggest? There is no vapor barrier here, just 2 x on top of the concrete block?
Old 03-21-2011, 10:02 AM   #4
HomeSealed's Avatar
So the top course of block is open on the top?... If that is the case, you would waste a lot of material by filling every block with foam. Stick a piece of xps board in the hole to fill it, then spray over the entire sill box... To further minimize foam usage, you could cut pieces of xps to fit the whole sill box cavity, then just foam the perimeter of it to seal it.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Insulating Sill Plate Atskodinski Building & Construction 7 12-18-2010 12:48 AM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 01:19 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
