Insulating A Shed Roof? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 01:16 PM   #1
Insulating a shed roof?
Got a lofted barn that I'm going to use part as storage and the other side for a shop. Going to heat and AC the shop so I will be insulating the walls and ceiling. Should I just insulate the ceiling or should I do anything with the roof? Also since the other side will be for storage and the loft area is common to both sides what can I do to help keep the shop side conditioned? The wall between will be insulated but should I insulate the ceiling of the whole building?
bmanley is offline   Reply With Quote
Old 11-03-2011, 02:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
Probably easiest and cheaper to just insulate the ceiling. Make sure it is air tight as well so you don't have any air/moisture loss.
No starter strip used on shed roof install? waterskier_erie Roofing/Siding 4 10-31-2011 08:25 PM
Shed roof construction questions wombosi Building & Construction 3 10-28-2011 10:01 PM
Drip edge for top side of Shed style roof with metal roof? organick Roofing/Siding 10 09-06-2011 08:43 PM
Flat roof insulating danomac Roofing/Siding 4 09-04-2010 09:43 AM
How much snow can my shed roof support? Critter68 Building & Construction 6 10-15-2008 09:53 PM
