Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-02-2012, 07:09 AM   #1
Insulating Recessed Rim Joist
I'm trying to insulate my rim joist. On the sides that are at the end of the joists, it is easy to slap up some foam board. However, on the side that parallels the joists, the rim joist is recessed behind the edge of the foundation. There is maybe a half inch gap for me to access it. Could I fill this with great stuff foam? Or just stuff it with fiberglass?
matt151617 is offline   Reply With Quote
Old 09-02-2012, 01:04 PM   #2
Stuffed-in fg will be useless; fg batting is not good material to start with. I'd go w/ spray foam everywhere you can apply the rigid. Be sure to tape/goo the edges of the rigid to air seal.
Old 09-03-2012, 02:09 PM   #3
So it's as simple as filling that gap with lots of great stuff?
Old 09-03-2012, 04:30 PM   #4
BTW: It should say "CAN'T apply the rigid", above. If you can ensure that air does not sneak in past the foam, I see no reason why this is any different than applying foam anywhere else. Even a layer of foam at the gap,to plug the area up, will give you a large dead air space, which is better than nothing. But, you have to make sure you air seal real well, either way. It's too bad this was not insulated as it was built and access was available.
Old 09-03-2012, 09:28 PM   #5
Moderator
That first joist is compromised anyway... What is above it on the floor- refrigerator, etc.?
Gary
Clothes taking longer to dry?
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 01:21 AM
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 09:27 PM
Dryer duct hole thru band joist & floor joist justplumducky General Discussion 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
