-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulating Recessed Rim Joist (http://www.diychatroom.com/f103/insulating-recessed-rim-joist-155552/)
matt151617 09-02-2012 07:09 AM
I'm trying to insulate my rim joist. On the sides that are at the end of the joists, it is easy to slap up some foam board. However, on the side that parallels the joists, the rim joist is recessed behind the edge of the foundation. There is maybe a half inch gap for me to access it. Could I fill this with great stuff foam? Or just stuff it with fiberglass?
http://img.photobucket.com/albums/v4...s/IMG_5586.jpg
http://img.photobucket.com/albums/v4...s/IMG_1843.jpg
http://img.photobucket.com/albums/v4...s/IMG_5945.jpg
http://img.photobucket.com/albums/v4...s/IMG_8122.jpg
jklingel 09-02-2012 01:04 PM
Stuffed-in fg will be useless; fg batting is not good material to start with. I'd go w/ spray foam everywhere you can apply the rigid. Be sure to tape/goo the edges of the rigid to air seal.
matt151617 09-03-2012 02:09 PM
So it's as simple as filling that gap with lots of great stuff?
jklingel 09-03-2012 04:30 PM
BTW: It should say "CAN'T apply the rigid", above. If you can ensure that air does not sneak in past the foam, I see no reason why this is any different than applying foam anywhere else. Even a layer of foam at the gap,to plug the area up, will give you a large dead air space, which is better than nothing. But, you have to make sure you air seal real well, either way. It's too bad this was not insulated as it was built and access was available.
Gary in WA 09-03-2012 09:28 PM
That first joist is compromised anyway... What is above it on the floor- refrigerator, etc.?
Gary
