Insulating A Pole Barn - Insulation - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 10:24 AM   #1
Rewards Points: 20
Insulating a pole barn
Hi everyone I am looking for suggestions and ideas on insulating my 30x40 pole barn. I have a wood burning stove to heat it with. I'm into wood working so I would like to keep the rafters exposed to store stuff in the rafters. I'm not sure what would be a good way to insulate the ceiling/roof and keep the rafters open. Also I have a sliding barn door I would like to try figure out a good way to seal it shut. I thought about covering the inside frame with plastic just during the winter to keep some draft out. Let me know what you guys did with your out building or any suggest or thoughts anyone might have. Thanks
golfthis1123 is offline   Reply With Quote
Old 12-02-2013, 12:08 PM   #2
Registered User
Rewards Points: 526
Describe the framing/roofing....
Gary
Old 12-02-2013, 08:11 PM   #3
Rewards Points: 20
The trusses are w kind. There is 4x6 every 8 feet and 10 feet tall to the rafters. I thought about putting insulation between the girts and osb on top of that for the walls
Old 01-01-2014, 01:56 PM   #4
Professional nut buster
Rewards Points: 26
"I'm into wood working so I would like to keep the rafters exposed to store stuff in the rafters."
A good portion of your heat loss is going to be up into the rafters. You need to put in a ceiling and insulate it with at least R38. Then you can make some racks hanging down from the ceiling for your storage.
What part of the country are you in?
Also, that sliding door is going to be one major loss of energy. An overhead door would be a much better choice.
Dragfluid is offline   Reply With Quote
Old 01-03-2014, 08:43 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Where is the home?
Old 01-03-2014, 08:53 AM   #6
Rewards Points: 20
Around dayton, ohio
Old 01-03-2014, 08:57 AM   #7
Rewards Points: 6,652
Can you post some pictures of the exterior and interior of the barn. You may have to build a room to be your working area in there Due to the makeup of most Pole Barns, have too many holes in them, that makes it hard to just insulate.
Old 01-03-2014, 09:33 AM   #8
Rewards Points: 20
I'll try to get some more pictures of the barn soon . It's a mess as you can see from the pictures I'm in the process of cleaning it up. Thanks again to everyone
Old 01-03-2014, 09:44 AM   #9
Foam in the sections, then cover with a layer of the metal sheathing. In most steel type warehouses, they use Fiberglass Insulation, since it does not burn like XPS, but is not as good of a insulator.
Vapor barrier for a Pole Barn maddog1 Building & Construction 3 08-22-2012 10:18 AM
400 amp service pole barn and home later walt1955 Electrical 2 06-29-2012 09:08 AM
Can you raise the roof on a pole barn after it's built? LMPD Building & Construction 12 03-24-2012 10:06 AM
Horse Barn Wiring - Pole Barn hagler Electrical 5 03-02-2012 10:23 PM
Wiring Detached Pole Barn wparker Electrical 8 06-17-2011 08:06 PM
