-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulating a pole barn (http://www.diychatroom.com/f103/insulating-pole-barn-191328/)
golfthis1123 12-02-2013 10:24 AM
Hi everyone I am looking for suggestions and ideas on insulating my 30x40 pole barn. I have a wood burning stove to heat it with. I'm into wood working so I would like to keep the rafters exposed to store stuff in the rafters. I'm not sure what would be a good way to insulate the ceiling/roof and keep the rafters open. Also I have a sliding barn door I would like to try figure out a good way to seal it shut. I thought about covering the inside frame with plastic just during the winter to keep some draft out. Let me know what you guys did with your out building or any suggest or thoughts anyone might have. Thanks
Gary in WA 12-02-2013 12:08 PM
Describe the framing/roofing....
Gary
golfthis1123 12-02-2013 08:11 PM
The trusses are w kind. There is 4x6 every 8 feet and 10 feet tall to the rafters. I thought about putting insulation between the girts and osb on top of that for the walls
Dragfluid 01-01-2014 01:56 PM
"I'm into wood working so I would like to keep the rafters exposed to store stuff in the rafters."
A good portion of your heat loss is going to be up into the rafters. You need to put in a ceiling and insulate it with at least R38. Then you can make some racks hanging down from the ceiling for your storage.
What part of the country are you in?
Also, that sliding door is going to be one major loss of energy. An overhead door would be a much better choice.
Windows on Wash 01-03-2014 08:43 AM
Where is the home?
golfthis1123 01-03-2014 08:53 AM
Around dayton, ohio
gregzoll 01-03-2014 08:57 AM
Can you post some pictures of the exterior and interior of the barn. You may have to build a room to be your working area in there Due to the makeup of most Pole Barns, have too many holes in them, that makes it hard to just insulate.
golfthis1123 01-03-2014 09:33 AM
5 Attachment(s)
Attachment 79559
Attachment 79560
Attachment 79561
Attachment 79562
Attachment 79563
I'll try to get some more pictures of the barn soon . It's a mess as you can see from the pictures I'm in the process of cleaning it up. Thanks again to everyone
gregzoll 01-03-2014 09:44 AM
Foam in the sections, then cover with a layer of the metal sheathing. In most steel type warehouses, they use Fiberglass Insulation, since it does not burn like XPS, but is not as good of a insulator.
