Insulating The Outside Wall In Bath Reno - Insulation - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 06:30 PM   #1
Rewards Points: 242
Insulating the outside wall in bath reno
Thanks for all the help, previously. I have one more thing that you guys can help me with. Actually there are a lot more, but right now, this one...lol...
I'm getting ready to insulate the outside walls in my bathroom reno...so do I use craft paper backed fiberglass, or unbacked fiberglass and 6 mil plastic...taped.
Just wondering...
Ed911 is offline   Reply With Quote
Old 11-25-2012, 12:36 AM   #2
Rewards Points: 1,092
probably neither. refresh us again on what your wall assembly is, from inside out. thanks.
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (11-25-2012)
Old 11-25-2012, 05:03 PM   #3
Rewards Points: 242
Gutted down to the studs...with exterior plywood sheathing and then brick.
Old 11-25-2012, 07:50 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Seal any seams or gaps in the plywood to avoid air movement or vapor push from outside.
Insulate with high density batt or better yet, roxul. Make sure your drywall is airtight.
No vapor barrier required.
Make sure your bath is vented properly.
Old 11-27-2012, 10:15 AM   #5
Rewards Points: 242
Originally Posted by Windows on Wash View Post
Seal any seams or gaps in the plywood to avoid air movement or vapor push from outside. Insulate with high density batt or better yet, roxul. Make sure your drywall is airtight. No vapor barrier required. Make sure your bath is vented properly.
Venting is via an oversized exhaust fan. The plywood is in good shape. I haven't been able to find any gaps to seal.
I was just wondering why no vapor barrior...if so, then why the craft paper insulation product.
BTW...thanks for your input. Ed
Old 11-28-2012, 08:35 AM   #6
Rewards Points: 894
Not really indicated for your climate. Your vapor control recommendations can be supplied by painted drywall.
Make sure your drywall approach is air tight.
Old 11-28-2012, 08:39 AM   #7
Rewards Points: 242
Bathroom insulation advice...
Thanks...looking in to the Roxul solution. Expensive, but in light of not needing a vapor barrier...I like it so far.
Thanks, Ed
Insulating an OSB sheated wall moon48 Insulation 1 06-22-2011 03:12 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Insulating Knee wall attic space Bloodta Building & Construction 3 12-14-2010 11:48 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
