Insulating An OSB Sheated Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 10:13 PM   #1
Insulating an OSB sheated wall
I have an insulated metal building with no climate control. I'm sectioning off a portion of the building and will install a window unit to keep that area cool. The wall will be 2x4 studs sheated with 7/16th OSB on both sides. I didn't plan on painting the wall or doing anything else to it.I live in South Louisiana. What is the best way to insulate the wall?
moon48 is offline   Reply With Quote
Old 06-22-2011, 03:12 PM   #2
Rewards Points: 95
Insulation
You are trying to keep the heat out?
It rather depends on what you are trying to achieve.
At a minimum glue 4 inch thick sheets of polystyrene over the outside (on the hot side).
Perry525 is offline   Reply With Quote
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Insulating existing basement wall tigereye Remodeling 1 12-28-2009 07:24 AM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Insulating above block wall that is above sheetrock klein General DIY Discussions 6 12-11-2008 10:37 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
