-   Insulation (http://www.diychatroom.com/f103/)
-   -   Insulating an OSB sheated wall (http://www.diychatroom.com/f103/insulating-osb-sheated-wall-108300/)
moon48 06-20-2011 09:13 PM
I have an insulated metal building with no climate control. I'm sectioning off a portion of the building and will install a window unit to keep that area cool. The wall will be 2x4 studs sheated with 7/16th OSB on both sides. I didn't plan on painting the wall or doing anything else to it.I live in South Louisiana. What is the best way to insulate the wall?
Perry525 06-22-2011 02:12 PM
Insulation
You are trying to keep the heat out?
It rather depends on what you are trying to achieve.
At a minimum glue 4 inch thick sheets of polystyrene over the outside (on the hot side).
