Insulating Open Rafter Ceiling - Insulation - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 11:05 PM   #1
Insulating open rafter ceiling
I am remodeling a ranch house with open rafter ceiling (after removing ceiling joists). I like the look of the roof rafters and I am trying to figure out how to insulate. My plan is as follows:
1. install 2" thick or 2 x 2" thick rigid foam insulation, with a 3/4" air space between the deck material between the roof rafters.
2. Install 1/2" thick gypsum board over the rigid insulation, with possible nailing surfacefor gypsum board which would give me another air space
3. I want to expose at least 1/2" or 1" of the roof rafters, whidh will stick out of the gypsum board finish.
I might not have enough R value for the insulation, but I plan on redoing exterior roof and might add additional insulation on outside.
Does anyone see any problems with this method?
thank you for any feedback
archnyc is offline   Reply With Quote
Old 02-19-2012, 12:43 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I am a bit stunned...
...you removed your ceiling joists?
Are you aware that you might have compromised the structural integrity of your house by doing this?
Unless your roof rafters are attached to a ridge beam (not a ridge board) your walls may at some time bow out and the roof system come down.
And yes, I can envision other problems with your insulation scheme but you are not providing enough information on that account.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-19-2012, 12:48 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You probably shouldn't have done that. Are your walls still straight?
titanoman is offline   Reply With Quote
Old 02-19-2012, 06:10 AM   #4
I have a wall under the ridge board, stiffened with plywood and also added metal ties that connect rafters to vertical surface. My walls are straight and I don't see how the walls would bow out.
What problems could I have with my insulation scheme?
Old 02-19-2012, 10:04 AM   #5
Rewards Points: 13,300
You needed a ridge beam. not a ridge board. Big differance.
Before you go to far with this how about some pictures.
No one here has any reason to cut down your idea, but without making provisions to stop those walls from bowing out there's going to be trouble down the line.
Those hurricane ties you installed are to stop roof up lift not the stop the rafters from forcing the walls out.
Old 02-19-2012, 10:25 AM   #6
I have buid a bearing wall under the ridge board, which sits on a bearing beam below. Then I have plywooded the wall and now I'm adding metal ties to keep the exposed rafters attached to wall. See pic
Let me know what you think
Old 02-19-2012, 10:36 AM   #7
Alternately, if you guys think this doesn't work, I can put back joists at 48 OC and leave them exposed
Old 02-20-2012, 12:47 AM   #8
Registered User
Rewards Points: 5,236
I would get a building permit for the structural changes made. Just for the full bearing aspect of your plan and the required reinforcing the support of the wall below,through the joist-space with solid blocking, in the basement/crawlspace to the earth.
Your AHJ may require engineering.
The rafter ends may require covering as they are not beams or logs with a different fire-rating than wood light-timber framing. Code requires minimum 1" air-space, and that's like a "D" on a school test...... Going with foam on the roof deck later will be worthless with the air-space you will have from now, choose one or the other. Hot roof or cold roof. http://www.buildingscience.com/docum...rchterm=attic+
http://www.buildingscience.com/docum...d-roof-systems
Gary
P.S. You may need solid blocking under the plywood wall to transmit forces from the roof to the ground, they appear to be missing. It could be my eyes...LOL. Looks to be an opening with ridge board unsupported, too.
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
insulating 2x6 rafter bays- not enough room! roadk Building & Construction 6 09-29-2008 08:32 AM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 10:14 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
