Insulating Non Accessible Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 12:37 PM   #1
In a little over my head
Rewards Points: 706
insulating non accessible attic
I will soon be installing insulation in my new bathroom addition. 80 sq ft. The roof pitch is very shallow; 2.5 in 12. Soffit vents and a 10" round roof vent. Height at the ridge is only 1' above the 2x8 ceiling joists. So the attic will be inaccessable after the sheetrock is installed. All the wiring is above the joists, due to lack of access below. No junction boxes, tho. IC, airtight recessed lighting. What's the easiest way to install adequate insulation? I'm thinking fiberglass batts and support rods like these: http://www.soundaway.com/IS16_Insula...rt_p/22009.htm, before the sheetrock is installed.
Any better/easier solutions? Or am I missing something?
ratherbefishing is offline   Reply With Quote
Old 11-06-2011, 07:56 PM   #2
Computer Nerd + DIY'er
OhmZoned's Avatar
Originally Posted by ratherbefishing View Post
I will soon be installing insulation in my new bathroom addition. 80 sq ft. The roof pitch is very shallow; 2.5 in 12. Soffit vents and a 10" round roof vent. Height at the ridge is only 1' above the 2x8 ceiling joists. So the attic will be inaccessable. All the wiring is above the joists, due to lack of access below. No junction boxes, tho. IC, airtight recessed lighting. What's the easiest way to install adequate insulation? I'm thinking fiberglass batts and support rods like these: http://www.soundaway.com/IS16_Insula...rt_p/22009.htm, before the sheetrock is installed.
Hi there - I am in the same predicament it would seem. Here is my attic (link)
I also do not have IC rated lights ...yet! Once I get everything air sealed and prepped, I am going to use blown in Atticat insulation in the entire place (up to 20" @ r-61). I will even be blowing the insulation on top of an old roof which has been closed in by a newer roof.
I would be curious what your research shows as well.
Ohm
OhmZoned is offline   Reply With Quote
Old 11-11-2011, 06:14 PM   #3
Rewards Points: 706
Don't seem to be getting any replies. Hmmm.
What is the best, easiest, most cost effective way to insulate an attic that will be inaccessible once the sheetrock is installed?
Old 11-11-2011, 06:24 PM   #4
DIY staff
Rewards Points: 7,174
Rather B---This is the first time I've seen this post---An I don't miss much---
Someone will help,soon.---Mike---
Old 11-12-2011, 07:46 PM   #5
Registered User
Rewards Points: 5,516
OZ, sounds as if you need to start a new thread in "Electrical" for those questions. Insulating on top of the existing old roof would be wasteful unless the space below is fully insulated. Any air gap between roof framing/insulation below would not help/work. No atticat: post #18- here: Attic Insulation: Should I use fiberglass or cellulose? follow the link I gave.
RB, have you looked in to conditioned attics?
http://www.buildingscience.com/docum...rchterm=attic+
Gary
Old 11-13-2011, 09:30 AM   #6
OhmZoned's Avatar
Gary
I have replied\updated my original attic insulation post based on this very helpful information.
Here is a link to my original post: Help with complicated insulation project in attic.
Old 11-13-2011, 09:46 AM   #7
Rewards Points: 706
It appears I did not do my own research before asking the question. I had previously only installed insulation under floors. I now see that in a ceiling installation, the facing has a staple flange that will hold the insulation up until the drywall is installed.
Old 11-14-2011, 09:46 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,742
Easiest way would be to make sure you have vent chutes at the eaves and blow in cellulose.
Old 11-14-2011, 03:01 PM   #9
Rewards Points: 706
Windows,
By vent chutes, do you mean the baffles that attach to the underside of the roof decking, to prevent the insulation from blocking the soffit vents and allow air in, or an opening to blow in the insulation? I have installed the former.
Or are you suggesting that I install almost all of the ceiling, then blow in cellulose, then add the last piece of sheetrock? I was not planning on having any access hatch, since the ridge is so low.
Thanks!
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 07:57 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Insulating an attic for finishing Graye2 Building & Construction 2 12-14-2010 10:20 PM
Insulating attic with rigid foam giannit Building & Construction 0 01-08-2010 10:39 AM
Wiring Protection for Accessible Attic BillyDIY Electrical 6 11-05-2009 08:44 PM
