Insulating New Addition Full Basement - Insulation - DIY Chatroom Home Improvement Forum
Old 09-28-2013, 02:44 PM   #1
Rewards Points: 99
insulating new addition full basement
Im building a new addition in bergen county, nj -- 18'X18' with a full but unfinished block basement. exterior will have a bituminous coating, skim coat, gravel and perf pipe at the footing, and I'm planning on applying one of the cultured stone or brick products on the exposed portion of the wall (about 1.5' above ground). inside will be gravel bed, 6 ml poly vapor barrier, and 4" slab on the bottom. this will be an unfinished basement used for storage. how best to insulate? would prefer to do inside I think? basement ceiling should be as well? even if (or perhaps because?) i use radiant heat? thanks as always.
yellowkid is offline   Reply With Quote
Old 09-30-2013, 02:02 PM   #2
Registered User
Rewards Points: 5,266
Location?
Gary
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 07:19 AM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 11:32 PM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-27-2009 12:10 AM
