Insulating My Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 12-30-2016, 11:14 AM   #16
Steam Ice Dam Removal Guy
Rewards Points: 18
Definitely duct work above ceiling. So you are saying synthetic felt is worse for open cell spray foam? I told the building maintainer that they have major problems coming up, but they didn't want to hear it. Plywood us buckling in several spots on the building and they get random leaks when it's cold.
fred icedam is offline   Reply With Quote
Old 12-30-2016, 01:13 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Re: Insulating My Attic
They are hosed either way at this point. The roof has to come off and the foam is coming with it if enough of the sheathing is shot. If it is just near the bottom or in selective areas, you could replace those sections and either cover the foam with a layer of CC SPF or another vapor control layer.
If the roof is already buckled in a bunch of other spots, probably better to just rip the whole thing off at that point.
I contend that whether they used felt vs. synthetic is of little to no consequence. The shingle aren't breathing to let the moisture out either way.
http://www.owenscorning.com/NetworkS...tober-2011.pdf
Old 01-02-2017, 11:55 PM   #18
Registered User
Rewards Points: 526
Fred, So... like I said (links and quote) that you needed an interior vb in post 7 and 9... maybe all my questions confused you, sorry.
WoW, thanks for leaving a link I used on this forum a few months ago for me- I'm familiar with it, but you missed the point and that link doesn't pertain. I'll start a new thread with the same question for others later...
ARAMP1; it would be pretty difficult the "surgically" insulate the existing floor, unless 2x12 joists. You need R-30 for your location; http://energycode.pnl.gov/EnergyCode...tate=Tennessee So if you have 2x10 (or smaller) floor joists, you need to compress R-38 (12") down to the 9-1/4" joists; http://www2.owenscorning.com/literat...20Bulletin.pdf
Build a new deck stacked over the existing to get required insulation in, same length/span with 1/2" shims between. IMO. no OSB if in UN-conditioned attic, open to exterior air, esp. Aspen species.
Gary
Old 01-03-2017, 06:51 AM   #19
It was actually for Fred as I was conversing with him.
I didn't see your name listed as an author on that whitepaper from OC. My apologies if I somehow cited information that created without proper credit.
Good to have you back policing the links.
Old 01-03-2017, 06:58 AM   #20
Rewards Points: 18
What if you put ice and watersheild over section leaking with spray foam?
mini-split in attic for whole house cooling Decca HVAC 9 01-04-2016 03:07 PM
Ventalating and Insulating attic properly? tvolsr1 Insulation 2 04-17-2015 01:36 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
finishing insulating attic Roundeye Insulation 12 01-12-2012 09:10 PM
