I am having a real bad condensation problem in my metal building. I continually have water coming out of my boat and that is bad. It is a 25x30 metal building with a metal fram ever 3 foot with metal panels screwed in to it. What would be the easiest/cheapest way to insulate it? I am not worried about keeping the heat from my fireplace in but I am wanting to cut down on the condensation. THanks for the help.
You are suffering from the "thermal short circuiting" caused the the steel beams, columns, trusses and girts. They tranfer the temperatuer difference quickly and the interior surfaces will always be much,much colder than all other surfaces and the interior air will condense and be released. To avoid filling he boat with water, eliminate the humidity and drop the temperature and provide some ventilation or put poly over it.
Insulating will do little unless it covers/protect the steel surfaces since that is where the water comes from and drips down.
I stored my boat for winters is an unheated, leaky wrinkled tin building and had no moisture problems. - It was big outboard but it could be run and drained in case of freezing.
If you are going to heat it, you are going to introduce more than tolerable amounts of humidity into the space than the thermal bridging of the steel can stave off.
Best way (albeit most expensive) is to spray foam it.
years ago it was several dollars/sf up here, 2" thick. "several" being about $3.50, if i recall. call a few places and let us know; i bet it is around $2.50/sf for 2" thick.
tuck: i am well aware of how much it hurts to spend money. trust me; i'm half scottish! however, there is no sense in owning a building and not taking care of it. rebuilding one ain't cheap, either. close your eyes and dig out the cash; it only hurts once, and you'll have a good, warmer building for a long time. if nothing else, the resale value will be improved, and you can recoupe some of your money then..... or your kids will.... cheers.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
