Insulating Low Pitched Roof With Vaulted Ceilings Inside - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2013, 09:00 PM   #16
Registered User
Rewards Points: 5,516
If the coating worked you would see many many more white colored (coated) roofs... vent the roof (add ridge vents) and insulate to minimum code requirements for your location (R-30) http://publicecodes.cyberregs.com/ic..._11_sec002.htm
More on unvented, expect a 10% service life reduction for asphalt shingles; http://www.buildingscience.com/docum...on?full_view=1
Hot climates; http://www.buildingscience.com/docum...n-hot-climates
Check with your local AHJ, venting may be required.
Gary
Covered patio structure pitched roof WHBIII Building & Construction 8 06-01-2011 04:52 PM
Insulating an A-Frame Roof jim8400 Roofing/Siding 0 11-28-2010 09:54 AM
Insulating area under roof... BlueBSH Building & Construction 10 11-08-2010 12:43 PM
Insulating cape-cod style roof w/attic room darin_i Building & Construction 8 11-04-2010 01:34 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
