Insulating Low Pitch Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 12:45 AM   #1
In a little over my head
Rewards Points: 706
insulating low pitch attic
I'm about ready to start insulating my addition. I'd planned on using R-19 (code here) above the ceiling, but was convinced to buy R-30 instead. But my roof is such a shallow pitch (2.5/12) that the ceiling to roof is only 6" at the top plate. I do have the foam air channels stapled to the underside of the roof for ventilation. Even at the ridge, there's barely a foot and a half or so. It looks like R-30 wants to puff up to 9.5 inches or so.
Am I better off compressing the R-30 near the walls, or using R-19 (6.5" thick) and letting it puff up like it wants to?
ratherbefishing is offline   Reply With Quote
Old 12-11-2011, 11:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,664
You would be better with a rigid foam layer that could double as your vent chute and adjust your depth as needed as you go up.
http://www.buildingscience.com/docum...f-venting/view
Old 12-11-2011, 12:40 PM   #3
Rewards Points: 706
Thanks, WoW. It looks like I have a little reading to do.
insulating attic eastside Insulation 10 09-09-2011 11:03 AM
Insulating Interior/Exterior Wall Cavity? Old Home from Attic HandyFrank Building & Construction 3 02-07-2011 10:49 AM
Plugging ceiling air leaks before insulating attic? dvs HVAC 5 12-02-2010 05:44 PM
insulating attic walls maverick1096 Building & Construction 5 07-25-2010 01:38 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
