Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-11-2012, 02:22 PM   #1
Question
Insulating a lean-to off the back of my garage. Need advice on what kind to get
I have an 18" wide x 9' deep x 6'6" tall room off the back of the garage. I re-framed 2 of the walls and shored it up, now I'm ready to insulate it to use as a small office.
Home Depot recommends R18 on the walls and R38 on the ceiling. Is this correct?
Also, where can I go to get this stuff cheaper? It seems that lining my roof with R38 will cost over $1000. That seems high.
I live in California. Thanks for the replies!
spdorsey is offline   Reply With Quote
Old 04-12-2012, 09:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
http://publicecodes.citation.com/ico..._11_sec002.htm
Old 04-12-2012, 10:00 AM   #3
http://www.energystar.gov/index.cfm?...sulation_table
What size wall studs do you have?
Old 04-12-2012, 06:41 PM   #4
Just a DIY guy
As Joe's map shows, California has five different zones in it.
I live in Zone 3 and have R19, because that's what the house came with. Might be nice to have more, but first I need to air seal the attic before it will do much good. But nearly everybody around here has the same thing.
Which begs the question, how airtight is this "lean-to"? If you have a drafty door and leaky walls/windows, going to the full recommended R value is not going to be good value.
And how are you calculating $1000 for an 18x9 roof? That's 162 square feet. Both of the R38 batts advertised on the HD site are exactly $1 per square foot.
This one is 64 square feet, look at the specs
http://www.homedepot.com/h_d1/N-5yc1v/R-202585891/h_d2/ProductDisplay
M3 Pete is offline   Reply With Quote
Old 04-14-2012, 12:32 AM   #5
Moderator
California has its own Energy Code. San Jose is in Zone 3C, requires R-38 in ceiling, R-25 in walls, pp. 13: http://www.pge.com/includes/docs/pdf...ones_01-16.pdf
Call around for best prices......
Gary
Clothes taking longer to dry?
Tags
ceiling, fiberglass, insulation, walls
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Insulating an unfinished garage TJMS81 Building & Construction 7 01-26-2011 12:19 AM
Insulating a garage leted_82 Building & Construction 14 12-13-2007 04:57 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
advice for insul./vent. of garage roof? King Dark Lake Roofing 3 04-15-2007 02:37 PM
