Insulating Interior Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 08:27 PM   #1
Insulating interior walls
Are there any major disadvantages to insulating interior walls including ceilings/floors of a split level ranch house witha walkout finished basement? My reasons for insulating would be for sound deadening purposes. I dont mean every wall in the house, but probably the downstairs den (walls and ceiling) and 2 bathrooms and possibly the master bedroom. I thought I remember reading somewhere that it is not a good idea for airflow or something but I cant remember exactly.
Maine1 is offline   Reply With Quote
Old 12-05-2012, 10:27 PM   #2
Registered User
Rewards Points: 4,936
You shouldn't have/want airflow through a wall, under, or over it anywhere, any wall. Roxul works well and rigid, split polystyrene on the plumbing stack/vent/drains. I always insulate under the stairs as well.
Gary
Old 12-06-2012, 12:39 AM   #3
Rewards Points: 1,092
sound deadening; search here. tons of info. basically, extra sheet rock, insulation, close any holes.
insulating crawl space rhader Insulation 5 11-07-2012 01:02 PM
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
