Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-01-2011, 03:37 PM   #1
Insulating Interior Walls
Is faced insulation bad for interior walls? I realize it is probably best to use non-faced but I have some left over kraft faced R-13. Should I just rip the paper face off, or would it not make a big difference if I left it on?
HandyFrank is offline   Reply With Quote
Old 11-01-2011, 05:15 PM   #2
Exterior Construction
Windows on Wash's Avatar
You don't need a vapor barrier but make sure it is to the warm side if you do it.
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
