Insulating Interior Basement Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 04:13 PM   #1
Insulating interior basement walls
Hello,
First, I'd like to apologize for my lack of experience---I'll likely use some incorrect terms.
I just bought my first house and the basement has a partially-finished room that I would like to use for an office. It is wired, vented, and has drywall up with 2 walls being external and 2 being internal. Unfortunately, they failed to insulate the external walls before, so I know I need to do that. My home inspector suggested having loose insulation sprayed rather than taking down the walls.
My question is regarding the two interior walls. Do I need to insulate these from the rest of the unfinished basement? Eventually I would like to finish the entire basement, but it would likely be a year or two before that happens.
brazzle is offline   Reply With Quote
Old 05-03-2011, 09:55 PM   #2
Registered User
Rewards Points: 4,924
Welcome to the forum!
Where are you located?
Is there poly sheeting plastic on the concrete?
Gary
Old 05-03-2011, 10:03 PM   #3
Thanks for the reply. I am located in Utah and no, there is nothing covering the concrete walls and the ceiling has exposed batting in the non-finished areas.
Old 05-04-2011, 08:24 PM   #4
Registered User
You are in either Zone 5 or 6; http://publicecodes.citation.com/ico...001_par001.htm
http://publicecodes.citation.com/ico..._11_sec002.htm
I recommend using rigid foam board glued tight to the concrete wall with no vapor barrier: http://www.buildingscience.com/docum...ent-insulation
In the unfinished area, I would install a house wrap as an air barrier on the floor joists to prevent wind-washing of the fiberglass; The "biggest loser" in fiberglass insulation....
Foam board the rim joists after air sealing any/all wiring/plumbing holes to above; http://www.buildingscience.com/docum...m-at-rim-joist
http://www.wag-aic.org/1999/WAG_99_baker.pdf
Gary
insulating basement rec room walls. jdabroski Building & Construction 4 12-16-2010 11:27 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 10:50 AM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 01:04 PM
Insulating Existing Walls DarkWolf Building & Construction 2 03-06-2009 11:01 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
