Insulating Inside Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 11:19 AM   #1
Rewards Points: 81
I am finishing my basement. I am insulating the interior wall between two bedrooms. I am also insulating the wall between the bathroom and the bedroom. I am adding this insulation only for some sound deadening. I realize I don't need insulation with vapor barrier but I have some left over from the outside walls. Since I don't really want any vapor barrier on these inside walls, should I cut some of the vapor barrier out of the bats after they are hung so any moisture can move freely?
OhioDon is offline   Reply With Quote
Old 07-02-2011, 12:29 PM   #2
i would just peel the vapor off of the fiberglass and use the unfaced bats that way
Old 07-03-2011, 12:50 PM   #3
It really doesn't make much of a difference on an interior wall. If you are concerned put it up normally then slash the vapor barrier, unfaced tends to fall when you are installing the drywall. Also if doing it for sound seal all the holes between the studs where the wires go it will help
parts is offline   Reply With Quote
Old 07-04-2011, 02:18 PM   #4
Registered User
Rewards Points: 5,498
I hope you used the faced insulation only on the above-grade walls, never in front of concrete below grade....
BTW- Slashing the paper vapor retarder does little to nothing stopping vapor, it will however, compromise an air-barrier, pp.5: http://www.buildingscience.com/docum...researchreport
Gary
insulating basement rec room walls. jdabroski Building & Construction 4 12-16-2010 10:27 PM
Insulating interior walls - soundproofing Branden Building & Construction 2 11-16-2010 12:05 PM
Insulating Exterior Walls in an Old House jerseyguy1996 General DIY Discussions 2 10-13-2009 10:11 AM
mold inside exterior walls brian73 Remodeling 1 10-03-2009 02:17 AM
Clicking inside walls after use of water Jax newbie Plumbing 4 02-23-2008 12:48 AM
