Insulating Floor-joists In A Crawl Space. - Insulation - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 09:57 PM   #1
insulating floor-joists in a crawl space.
Moisture is the consern with a wood frame house. What type of insulation should I use, are louvers necassary behind insulation for ventilation and what do i use to fasten the insulation: staples thin metal rods that flex?
Waylon is offline   Reply With Quote
Old 10-01-2011, 11:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
Spray foam is best in this case.
Rigid foam is the next best in my opinion.
Old 10-02-2011, 08:43 AM   #3
Experienced
Jackofall1's Avatar
Hello and welcom Waylon, to the best darn DIY'r site on the web.
Have you ever considered insulating the foundation and heating the crawlspace, helps keep the space dry and the floors warmer.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
HomeSealed (10-03-2011)
Old 10-02-2011, 11:06 AM   #4
Mark
+1
If the moisture content of the earth does not require a vented crawlspace, encapsulating (vapor barrier) across the floor and insulating the walls is ideal.
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 08:32 AM
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 05:58 AM
water in crawl space need advice puma80 Building & Construction 2 04-08-2010 10:07 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
