Insulating Floor... Ideas Please - Insulation - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 03:16 PM   #1
Insulating Floor... Ideas please
Insulating the floor... Any ideas?
Insulating Floor... Ideas please-imagejpeg_2.jpg   Insulating Floor... Ideas please-imagejpeg_2-1-.jpg   Insulating Floor... Ideas please-imagejpeg_2-2-.jpg
DukeLewis87 is offline   Reply With Quote
Old 07-03-2013, 03:21 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
curious, what is the size of the joist and the span? looks like 2x4's
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-03-2013, 04:08 PM   #3
2x6 Pressure Treated on 16" centers / 13ft span in 1st room. 16' span in the 2nd room.
Ill be running a 4x6 support beam down the 9.5" depth below floor joists. And ill be support the other portion with just blocks nailed to the side to brace the floor. I still have to level the joists out
Old 07-03-2013, 04:53 PM   #4
Support beam + braces haven't been installed yet in those pictures. But will be done after today.
Old 07-03-2013, 08:39 PM   #5
Foam Board? Insulation Bats?
Old 07-03-2013, 08:46 PM   #6
Rewards Points: 13,296
Seem to be missing a vapor barrier, joist hangers, blocking. I'd never use a 4 X 6 for a beam, they twist, check, and bow.
Is that wood pressure treated?
Old 07-03-2013, 09:20 PM   #7
The support beam is in place 18'10" as well as the other portion with blocks for height adjustments
My wood is fine......
2x6 pressure treated ac2
4x6 pressure treated critical structure
Cedar Shimmed
Joists hanger Triple Zinc for the 9.5" underneath the one area
Old 07-03-2013, 09:21 PM   #8
And why would I need a vapor barrier on this? Vapor barrier to prevent what moisture and from where?
Old 07-03-2013, 09:25 PM   #9
Sooooooo
Old 07-07-2013, 09:22 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
You will need a capillary break between the concrete and the insulation if you go with anything fibrous or hydrophilic.
Rigid foam will work well here and works well in basement slab applications.
Old 07-07-2013, 09:30 AM   #11
Civil Engineer
Rewards Points: 4,568
I would use solid foam, rated for a moist environment, as the concrete is going to wick moisture from the soil upwards. Not a huge amount, but some. You could use spray on foam if it is rated for direct contact with concrete, but the hard styrofoam (I used some Owens Corning dense pink stuff in my basement) can be cut to size easily and fitted, and will form a nice vapor barrier to keep your floor dry.
I too would be a bit concerned about twisting of the PT lumber as it changes moisture content. Maybe not a big problem, as this room may have a relatively constant moisture content. Just curious how you nailed the joists to the beams.
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
