Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-28-2012, 05:37 PM   #1
Insulating a Floor From the Basement
Hi!
Going to help a friend with cold floors on the first floor of his home. We plan to insulate the floor from below by accessing the unfinished basement.
My question is what type of insulation? Foil or paper? Also, thinking r19. Any suggestions? His house is in upper Westchester NY.
Thanks!!
JohnC20 is offline   Reply With Quote
Old 11-28-2012, 05:43 PM   #2
http://www.energystar.gov/index.cfm?...sulation_table
Has it been air sealed?
Are all the foundation vents closed?
If this is a crawl space is there a vaper barrier on the ground?
You need to go back and add your location to your profile.
Old 11-28-2012, 05:47 PM   #3
No no and no! Lol. The home is about 80 y.o. And it leaks air like a flat tire. No vapor barrier. Which is why I asked about foil or paper backed. The basement is unfinished, cobble stone walls.
Old 11-28-2012, 05:57 PM   #4
Ballon wall constrution, old leaking windows, almost no insulation in the attic, may or may not even have insulation in the walls, non T X G 1 X6's or hardwood installed with no subflooring?
God I love an old house, ching, ching. All I see is dollar signs.
Old 11-28-2012, 06:54 PM   #5
Glad it's my friends!!
Old 11-28-2012, 09:29 PM   #6
not all old houses are balloon. mine isn't, and never has been. its at least 80 years old.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 11-29-2012, 01:55 AM   #7
if the basement is conditioned (heated), fiberglass is ok, but roxul is better. if the basement is not conditioned and you can get to flat floor joists, fill them w/ batting if you want to and then cover them w/ rigid foam and tape/goo the edges. any batting in between joists leaves their edges cold, and you could get condensation on them. the rigid foam prevents that.
Old 11-29-2012, 07:06 AM   #8
Wow.. Ok. Not sure if he wants to spend the money on the foam... Thanks!
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Insulating my basement DanS281 Carpentry 1 08-28-2011 04:05 PM
Insulating unfinished basement, First time home owner please help! ashory Building & Construction 7 08-26-2011 12:44 AM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 07:19 AM
Insulating partial in-ground basement? HiccaBurp Building & Construction 6 10-25-2010 11:03 PM
