Insulating Floor Of Addition - Insulation - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 06:59 PM   #1
Rewards Points: 59
Insulating Floor of Addition
I am putting a small 2nd story addition on the back of our house. It is supported on columns, so the floor is open to the outside.
I am going to be using fiberglass batts between the floor joists, and am considering using a layer of 2" rigid insulation (XPS) below the floor joists (there is a bathroom with plumbing in the floor). My question is what do I do about a vapor barrier? Is it okay to use unfaced batts and use the 2" of XPS foam as the vapor barrier since it is vapor impermeable?
Thanks!
handyman923 is offline   Reply With Quote
Old 07-03-2012, 07:12 PM   #2
Rewards Points: 13,260
If the bottom is exposed, I'd used faced batts and Exterier rated t & G plywood, or for a better look 1 X 6 T & G on the underside.
Old 07-04-2012, 03:13 AM   #3
Rewards Points: 1,092
Vapor barriers are, in general, a no-go any more. Vapor retarding and air sealing is what you want to do. Your rigid foam will probably stop your joists from condensing, so I would sure use it and seal all gaps w/ Great Stuff and tape. Look for Roxul instead of fg batts; fg batts are a pp excuse for insulation.
Old 07-05-2012, 01:46 AM   #4
Registered User
Rewards Points: 5,212
No vinyl flooring; http://www.buildingscience.com/docum...n-crawlspaces/
Cover for critters and fire.
Gary
Insulating a kitchen sink in an addition mariann carcich Kitchen & Bath Remodeling 1 04-06-2012 08:35 PM
Incremental benefit of insulating rafters in addition to ceiling joist bays? benjamincall Insulation 13 12-26-2011 02:17 PM
Insulating Attic - Peaked Roof addition over Built-Up Roof nominivans4me Insulation 1 04-16-2011 12:27 PM
Insulating an addition cbollin Remodeling 1 02-03-2011 12:59 AM
Insulating and Underpinning a new addition annoyed Building & Construction 2 08-23-2009 06:04 PM
