Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-04-2011, 06:56 PM   #1
insulating a floor
What is the best way to insulate a floor that is part of an add on? My kitchen was added onto a older home and was never insulated. In the cold winters I can not stand on the floor with out socks and shoes. I have looked its only wood and tile above the dirt ground. What can I do to save on heating and to be able to properly use my kitchen without freezing?
coldfeet is offline   Reply With Quote
Old 09-04-2011, 10:05 PM   #2
Msradell's Avatar
insulating a floor
Using closed cell foam sprayed in would certainly be the best solution. It provides a vapor barrier, insulation and will prevent air infiltration. Installation is not a do it yourself project, it needs to be done by a professional. The price is certainly a little more expensive than fiberglass insulation but it also will stay in place forever so you don't have to worry about it falling down over time.
We used it under a portion of our kitchen that was over a crawl space and then change is a remarkable.
Msradell is offline   Reply With Quote
Old 09-05-2011, 12:16 AM   #3
Moderator
insulating a floor
http://www.buildingscience.com/docum...n-crawlspaces/
Gary
Clothes taking longer to dry?
Old 09-06-2011, 10:17 AM   #4
insulating a floor
I have an addition with a crawlspace as well. I read the building science article and plan on going with Figure 7 (fiberglass between joists and rigid insulation screwed to joists).
Everyone touts spray foam but around here is it still much more expensive than any other kind of insulation.
shazapple is offline   Reply With Quote
Old 09-06-2011, 11:20 AM   #5
Msradell's Avatar
insulating a floor
It may be more expensive but it's worth it in the long run!
Insulating floor of a bove ground sunroom rbyham Insulation 0 08-07-2011 11:49 PM
Insulating Floor Joists trophywalleye Building & Construction 7 02-01-2011 12:53 AM
Insulating a floor above an unheated crawl space Joe Vassallo Flooring 1 09-04-2010 07:33 PM
Insulating floor? Rexkwondo Building & Construction 6 01-04-2008 10:21 AM
Insulating Exposed Floor batou General Discussion 2 12-08-2007 11:04 PM
