-   Insulation (http://www.diychatroom.com/f103/)
-   -   insulating a floor (http://www.diychatroom.com/f103/insulating-floor-116205/)
coldfeet 09-04-2011 05:56 PM
insulating a floor
What is the best way to insulate a floor that is part of an add on? My kitchen was added onto a older home and was never insulated. In the cold winters I can not stand on the floor with out socks and shoes. I have looked its only wood and tile above the dirt ground. What can I do to save on heating and to be able to properly use my kitchen without freezing?
Msradell 09-04-2011 09:05 PM
Using closed cell foam sprayed in would certainly be the best solution. It provides a vapor barrier, insulation and will prevent air infiltration. Installation is not a do it yourself project, it needs to be done by a professional. The price is certainly a little more expensive than fiberglass insulation but it also will stay in place forever so you don't have to worry about it falling down over time.
We used it under a portion of our kitchen that was over a crawl space and then change is a remarkable.
Gary in WA 09-04-2011 11:16 PM
http://www.buildingscience.com/docum...n-crawlspaces/
Gary
shazapple 09-06-2011 09:17 AM
I have an addition with a crawlspace as well. I read the building science article and plan on going with Figure 7 (fiberglass between joists and rigid insulation screwed to joists).
Everyone touts spray foam but around here is it still much more expensive than any other kind of insulation.
Msradell 09-06-2011 10:20 AM
It may be more expensive but it's worth it in the long run!
