Strangely enough, my brother and I both own home that have sloped (gable) roofs that are built over flat roofs. Both are asphalt and gravel type roofs that someone built some trusses over years later. Both have no insulation inbetween the 2 x10's of the original flat roof. Mine has batts of fiberglass insulation laid on top of the asphalt/gravel flat roof. Given that the gable ends and the voids in the flat roof are not insulated it is very expensive to heat both of our houses (heating oil). As I have looked at how to insulate the roof it seems there are three options. 1. Pull down the drywall from inside and insulate with fiberglass batts and re-install drywall. I cant do this, because I am living there. 2. Spray in foam kits. I cant see how this would work because of the need to spray directly on the surface. Because you have to hold the spray gun in your hand and cant feed it down though a hole I cant see how thias would work. 3. Use a hole saw and cut holes in the flat roof than use blown in insulation with the machine you get from the DIY store into all of the voids. The problem I see with this (and please correct me if I am wrong), If I fill the voids without a vapor barrier, it will cause water to condense within the flat roof voids causing mold, water damage, etc. There is no way I can see to install a vapor barrier. Ive heard some say that the right ceiling paint can be a vapor barrier. This sounds questionable to me?????? Im lost and could use some help.
Are you saying that this structure used to have a flat roof, but some-one added trusses and now you have a pitched roof? What once was the flat roof area is now enclosed as attic space? Is the waterproof membrane from the flat roof still in place? Yes, you can buy paint with a low permiability rating to act as a vapor barrier. You'll need to go to a regular paint store.
Get out the phone book and look up insulation installers and make some calls to see what they think.
I've had to do this to a home one time and never want to do it again.
We cut out rectanguler shaped holes in the top side and blew in insulation.
We ended up using 1-1/4 PVC duct taped to the hose to be able to push it to the end of the wall to ceiling area.
Your working blind and just hoping for the best as you pull it back when filling.
Thanks for the reply guys! Yes, Maintenance 6, you have described the situation perfectly. It appears from my initial inspection that there was no vapor barrier installed originally. But I have only cut into one cavity. I will certainly look into the low permeable paint.
Joe Caption, I like the idea of the PVC pipe. Its a small attic and pretty tight up there, so Im sure moving around a PVC pipe up there will be no easy job, but never the less a great idea. Did you use the type of machine you can rent/borrow from Home Depot/ Lowes?
My home is located in Williamsport, MD just outside of Hagerstown.
Thanks again for the great replies, you have helped me immensely!
We don't really need a vapor barrier in this climate zone (Zone 4).
Are you saying the the gable ends of the sloped roof are open? If so, that is fine.
Is the flat roof vented in any capacity? If not, the easiest way to insulation is to make sure the flat roof is sealed against any air leaks and blow insulation over the top of it. That dead air space between the rafters does not really need to be insulated if it is trapped air but it needs to be sealed in order to make sure it is functioning as an insulator at that point.
The DIY insulation blowers will not be sufficient to dense pack fiberglass or cellulose so don't bother with them in that capacity. They will open blow so that is fine.
I’m with WW on this, do not insulate the cavity of the flat roof, cell., or f.g.
You have an impermeable layer on the flat roof decking, asphalt coating = a vapor barrier, adding another below (v.b. paint) will trap any moisture in the ceiling cavity. More importantly, you have no ventilation to remove the moisture from the wet cellulose or fiberglass insulation.
Insulate on the flat roof to raise the temperature of the cavity to prevent condensation, as per WW.
Regardless of the insulation, you should cut up or remove the old flat roof membrane so that it is not a moisture trap. Any moisture that moves upward from your living space is going to condense on the underside of that old roof when the air temperature is below dew point.
Ok so I forgot to mention that I do have rolled insulation in the attic on top of the old flat roof. I still have some significant insulation issues due to the fascia and the soffit. I drew a picture to illustrate (ok, so it looks like my 2 year old drew it!)
Looks like from your drawing, that the insulation you've got is almost useless. Air getting into the soffit can travel across the space between the old roof deck and your ceiling. You need to get the insulation into that space without blocking off the ventilation into the attic space from the soffit. I would cut up the old roof membrane so it doesn'tcause a moisture issue. Then I would put some blocking at the ends of the joist cavities to prevent closing off your ventilation. Then I would blow cellulose into the cavities and finally, I would coat the ceilings with a low perm paint for a vapor retarder.
Just put insulation over top then like you are doing.
If you wanted to get more technical about it, you could cut and put blockers inside the joist bays to get more R-Value at the outside wall but it is not totally necessary.
putting a pitched roof over an existing flat roof leaving the asphalt and insulation....is that safe? will the release toxic gas back into the house?
I'm interested in buying a house that has a pitched roof added to a flat roof.
Just not sure about the roof.
The owner got engineering plans and city permit, the addition looks OK. However, the job was not completed. They added insulation on top of the flat roof in some location, but not the entire roof.
I am in a similar predicament and initially was intending to blow in fiberglass. After enough research I decided against this and have been dismantling the flat roof. In my case most of the roofing was gone so all I need to do is remove the 1 by decking. Sounds like this will be impractical for you. In your shoes I might consider loose polystyrene balls blown in.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
