Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 05-14-2011, 10:47 PM   #1
Question
Insulating flat roof with exposed rafters
I have a 1950's home in Palm Beach County, FL. In an enclosed area that was once a screened porch and Florida room, the roof is 1x6 tongue and groove on 4x6 rafters spaced 24" oc. That is the interior ceiling; no insulation. The area is air conditioned but obviously it gets very hot in the summer. I would like to install insulation in a way that leaves the bottoms of the rafters exposed. One thought is to install 4" EPS block (~R-30) between the rafters with thermoplastic decorative tile below supported by inside corner molding. I've read a number of posts that talk about venting insulated ceilings and wonder if such an unvented installation would be workable. In any case, venting the rafters would be very difficult as one area is an interior room.
I would appreciate any comments indicating whether my idea is workable or not and any suggestions for alternatives, particularly ones that do not require installing a new ceiling on the rafters.
rblevow is offline   Reply With Quote
Old 05-14-2011, 11:00 PM   #2
well a picture would be nice but from what im getting, you have got 2 ways to insulate. put insulation on the inside and fur the beams down to keep them exposed or take the roof off and insulate form the outside with foam sheets and leave the inside alone. just my 2 cents
bluebird5 is offline   Reply With Quote
Tags
eps, insulate ceiling, insulation
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 05:16 PM
Flat Roof Resurfacing - Where to start? adamgram Roofing/Siding 9 09-05-2010 10:54 AM
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 12:24 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 11:31 AM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
