Insulating Flat Roof Deck - Insulation - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 04:33 PM   #1
No pain, no gain!
Rewards Points: 89
Insulating flat roof deck
What I have is a flat roof section, originally a built up roof (tar and gravel). I have had two roofers over, both of whom recommended putting insulating roof board on top of the existing deck and new roof on top.
The wrinkle is that the roof was built as a cold deck like the illustration. So roof board on top, without blocking the soffit vents does nothing for you as far as adding insulation value. Rafters are 2x10.
I have looked at the links from this thread, and it mentions two ways to proceed, roughly--
(1) rigid insulation above the roof deck + permeable insulation below, and no venting of the joist cavities;
(2)spray foam on the underside of the roof deck and ends of joist bays, permeable insulation between this and the ceiling drywall.
To do either well would involve sacrificing the plaster ceilings.
Both versions eliminate the venting as we have it now, with continuous soffit vents and free flow of air between the top of the insulation and roof deck---almost like a mini-attic.
Does a closed/no vent flat roof make sense, or is it worth trying to preserve our current system, using only enough roof board to reslope the roof?
(I've cross-posted this in the roofing section)
paredown is offline   Reply With Quote
Insulating options for flat roof marco529 Insulation 2 12-05-2011 03:57 PM
Insulating the Ceiling below a Flat roof question? Throy Building & Construction 2 09-24-2009 06:50 AM
install trek on flat roof of another room to creat deck? ckurita Building & Construction 11 05-23-2009 09:29 AM
Spray foam insulating ceiling under flat roof Jed Lukewater Remodeling 1 01-12-2009 07:22 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
