#1 |
Insulating/Finishing a Uniquely Pole Framed Room
My parents have an unfinished old 'garage' attached to their place. I'd like to insulate it and eventually finish it for them. The odd thing about the room is it's framed with vertical logs at roughly 24" on center. The outside edge of the logs has been sawed flat with 1" boards on this flat edge, but the insides are still round. The Rafters are done in the same way (cathedral ceiling). It seems structurally sound and everything is dry, none of the logs I 'poke' tested were soft. I love the way it looks inside, but they obviously can't use it as finished space in this way. I was thinking about putting foam board on the outside of the walls and roof and then re-roofing and siding over that. The inside however presents some difficulties. I'd like to keep the log look. I think it's very unique. Would it be possible to cut and trim foam board to fit in between these vertical logs and then plaster or stucco over the foam? Is it possible to plaster directly to foam board or should I use a lath product? Are there possible moisture issues sandwiching a 1" board like that?
#2 |
frame in between the logs. drywall as close to the logs as reasonably possible. mud to fill the remaining gaps. and sand with a wet sponge.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
#3 |
Moderator
Where are you located?
Gary P.S. Welcome to the forums!
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Room Air Purifier - which is best? | nhart | Appliances | 16 | 12-07-2012 07:00 AM |
| Soundproofing a basement room | MrAngles | Insulation | 5 | 06-06-2012 10:01 PM |
| Vapor Barrier on elevated 4 season room | Indyc0lt | Insulation | 3 | 09-15-2011 02:41 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
| Heat pump in non insulated nor heated room | robdville | HVAC | 3 | 01-21-2008 03:51 PM |
