Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-20-2012, 02:23 AM   #1
Insulating from exterior on old house
Need to insulate from exterior of old house. Want to remove old cedar siding insert R-14 backed batting and put up hardie planks.
Don't know if the batting and a tar paper is sufficient.
Old house has no insulation currently and know I can't blow any in.
Anyone got any knowledge in this area?
honeydolist1 is offline   Reply With Quote
Old 09-20-2012, 03:25 AM   #2
I don't know much but your location and climate are going to be important for temperature and dew point.
You want the wall to be able to dry in at least one direction.
strategery is offline   Reply With Quote
Old 09-20-2012, 07:38 AM   #3
Exterior Construction
Windows on Wash's Avatar
+1
Google exterior foam sheathing as well as rain screen walls.
Old 09-20-2012, 10:03 AM   #4
http://www.energystar.gov/index.cfm?...sulation_table
Somethings that will most likly need to be done if it's a really old house is fire blocking, sealing any holes where plumbing and wiring were done.
Up dating any wiring you find.
I saw no mention of any sheathing being used in your plan, ( I may have missed that) I would not install James Hardee over bare studs.
I would use house wrap not tar paper on the outside.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Insulating my old back house floor? 1910NE Building & Construction 4 09-30-2010 08:09 PM
Insulating Below Rafters in 1-1/2 Story House jbeuckm Building & Construction 2 09-29-2010 12:59 PM
Insulating Exterior Walls: House Built 1956 whiteblur Building & Construction 4 09-27-2010 09:11 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
