Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-03-2011, 08:52 PM   #1
insulating exterior basement wall
what is the best product to use to insulate the exterior basement wall 3ft of exterior wall is above ground. siding sticks out over basement wall about 1 inch. will dig down 1ft to start insulation or what is best recommendation
swrath is offline   Reply With Quote
Old 11-04-2011, 12:58 AM   #2
Moderator
Welcome to the forum!
Where are you located?
Gary
Clothes taking longer to dry?
Old 11-05-2011, 10:49 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1, where are you located.
What is above ground is not necessarily the cut off point.
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Insulating existing basement wall tigereye Remodeling 1 12-28-2009 07:24 AM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Insulating above block wall that is above sheetrock klein General Discussion 6 12-11-2008 10:37 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
