Insulating Existing Interior Walls - Insulation - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 09:04 AM   #1
Rewards Points: 35
Hello,
I am trying to figure out how much blown in insulation I need per sq ft for an existing interior wall.
Thank you
MAD King is offline   Reply With Quote
Old 03-27-2013, 09:16 AM   #2
Rewards Points: 13,712
Going to need more info and your location add to your profile.
Go to Quick links to edit.
No one here can see your house.
How deep, how tall and wide ECT.
http://www.energystar.gov/index.cfm?...sulation_table
Old 03-27-2013, 10:07 AM   #3
Rewards Points: 35
Hello,
didn't know that there is a R-Value for existing interior walls too.
What information would be needed?
I thought there would be an approx. amount of blown-in insulation per sqft for empty interior walls.
Old 03-27-2013, 10:40 AM   #4
And how would anyone here know just how thick these walls are or what type blown in your going to use unless you share the info?
Old 03-27-2013, 10:57 AM   #5
Rewards Points: 35
Sorry, but I am new to this and if I bother you with my inexperience please take my apology.
I think these are regular 4" walls with a reular height of 8'.
Type of blown-in insulation woul dbe cellulose.
Old 03-27-2013, 03:33 PM   #6
for soundproofing or separating thermal zones?
asinsulation is offline   Reply With Quote
Old 03-27-2013, 03:36 PM   #7
Rewards Points: 35
A little bit of both. But that wasn't my question.
Thank you
Old 03-27-2013, 03:52 PM   #8
I am well aware that wasn't your question, but your application is going to change depending on what your desired final result is buddy
Old 03-27-2013, 03:56 PM   #9
if thermal is the idea, you need to densepack. if sound is the idea, you want the cellulose a little loose, like a pillow.
Anyway, give me the width of the walls, and I will tell you how many bags you need to densepack. already have the height and depth, so just the width.
Old 03-27-2013, 04:02 PM   #10
or this is even easier. as long as your measurements are accurate above, you will need a little more then 3 and half bags for every 10 feet, assuming you are using 25 lb bags.
Old 03-27-2013, 04:08 PM   #11
Rewards Points: 35
Oh wow, thank you very much. That is very accurate.
Old 03-27-2013, 04:08 PM   #12
Rewards Points: 626
I would use Dense pack insulation if your going for sound and thermal zoning. just know there is settling with lose fill so you might want to check out doing a dense pack less settling.
Nailbags is offline   Reply With Quote
Old 03-27-2013, 05:04 PM   #13
The number I gave him is for densepacking, minus a little for framing members and the fact that if you haven't densepacked before, your not going to get it as tight as it should be. but he should find a happy median with this.
If it is truly a densepack, it will carry the vibrations and have no effect on noise reduction, and its not like we are trying to control a 30 or 40 degree temp difference as you would be on exterior walls. also, much less opportunity for moisture intrusion on the interior walls
Old 03-27-2013, 08:27 PM   #14
Rewards Points: 35
Thank you. I am trying to find where to buy dense pack, but google gives me only installation instructions.
Old 03-28-2013, 07:28 AM   #15
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,622
Be aware that dense packing is not a great DIY job. Not only are the blowers that you get as rentals equip to dense pack, it is an acquired skill that takes a good, long time to get good at.
Dense packing is usually a job for the pros.
Insulating beside existing basement stairs mae-ling Remodeling 0 10-16-2012 10:42 PM
Insulating Existing Garage with Polyiso Foam Board saxman2u Insulation 6 09-18-2012 01:45 PM
Insulating Behind Existing Drywall tofaute Drywall & Plaster 1 11-09-2010 09:56 PM
Splitting an existing circuit run JoeyBradshaw Electrical 1 09-24-2010 08:02 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
