Insulating An Existing Cement Basement Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 02:42 PM   #1
Insulating an existing cement basement wall
My basement partial wall has a vapour barrier over the cement then 2x4 and panelling.
I would like to install foam board insulation but wondered if the foam board should go over the vapour barrier or cut it out and put a new barrier over the foam then the drywall material?
reg russell is offline   Reply With Quote
Old 09-19-2011, 01:54 PM   #2
Below Grader
If you are using foam board insulation, according to the US Department of Energy, you don't need any vapor barrier, provided that you place it straight against the walls and seal the seams between boards with mastic tape.
Foam board insulation itself is impervious to water and acts as a vapor barrier.
Also, according to the US DOE, you do not need a frame to install the drywall. Furry strips can be installed over the foam boards to hang drywall.
http://www.eere.energy.gov/buildings...s/db/35017.pdf
CyFree is offline   Reply With Quote
Old 09-20-2011, 11:16 AM   #3
AGWhitehouse's Avatar
I concur...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 09-22-2011, 02:39 PM   #4
CyFree, I'm in the planning phase of finishing a room in my basement... Do i need to put the Foam board/ridgid Insulation directly to the concrete foundation or can i put up the 2x4 wall an then place the insulation in between the studs? I am trying to save space in this room and do not want to use 2x2s. The room is dry no issues with water except for condesation from the water main in the room.
Thanks for Help!
Tiny207 is offline   Reply With Quote
Old 09-22-2011, 08:11 PM   #5
Thanks for Help!
Look up z-furring...it's what you're looking for.
Old 09-23-2011, 08:32 AM   #6
I need to insulate the 2x4 wall against the concrete wall but cant give up any more the 4" (2x4 + drywall). The doorway to the room is next to the concrete wall and can't have the 2x4 wall on top of the ridgid insulation.
Or can I place the wall against the concrete and just use regular batt insulation?
Old 09-23-2011, 09:49 AM   #7
http://www.vobb.com/Other-products/Z-furring.jpg
assembly is 2-1/2" (2" foam & Z, 1/2" drywall)
Old 09-23-2011, 03:33 PM   #8
Sorry should be more in depth with my plans...
I am planning on mounting a 46" TV that weighs approx 50lbs... this wall will also have the recessed Electric/Cable/phone/home theater outlet for the TV running through it which is about 2 1/2" deep.
So it appears this Z furring will not hold this, along with any shelves i'd like to put up as well.
Thank You.
Old 09-23-2011, 06:43 PM   #9
msaeger's Avatar
Rewards Points: 260
Could you use screws long enough to go through the insulation and into the community concrete?
msaeger is offline   Reply With Quote
Old 09-25-2011, 09:50 PM   #10
Thank You.
You'll need 2x3 framing minimum for that 2-1/2" box. I can't recommend putting the foam within the stud bays.
You could use the z-framing and surface mount a 1-1/2" deep 4x4 box on the concrete and spray foam around it to fill flush the insulation. Then use a 1/2" stucco ring to bring the face of the box flush with the gypsum board. You'll have to provide a piece of 1/2" conduit down to the box within a routed out channel in the rigid foam. You can spray foam fill after the conduit installation.
Old 09-26-2011, 01:01 AM   #11
Registered User
Rewards Points: 5,180
Do more research on the Z-furring. Buy the G90 coating not the lesser thickness ones (G-40,60) due the wet nature of the foam board most of the year. The stored moisture would rust out the metal at the fasteners. I would use stronger studs than 2x3's for shelving........ not to mention a heavy tv.
Gary
Old 09-26-2011, 01:00 PM   #12
(1) 2x3 could certainly hold a 50lb. TV...Add two together with a plywood backer (the typical rough install for known bracketing) and you have an assembly that could easily hold you in the air...
Old 09-26-2011, 10:34 PM   #13
Registered User
Thanks for rest of the install information!
Gary
Old 09-27-2011, 10:57 AM   #14
Gary
"feel free to PM me rather than taking up valuable time/space from us both"
OP, if you're looking to have bookshelves and TV's hanging from the walls, then a typical stud frame wall is your best bet. If you really want the Z-furring option, then look into floor standing bookshelves. I believe a 2x3 stud partition will hold your tv just fine, but if your looking to have a library of books around it on wall mounted shelves, then look into larger studs.
Last edited by AGWhitehouse; 09-27-2011 at 01:28 PM. Reason: People should heed their own advice...
Old 09-30-2011, 11:02 AM   #15
Interesting post - I have a walk out basement (fully exposed walls) and am going to reside with tyvek, foam board, siding. I read over the DOE-generated doc at the link above and it appears that insulation differs between in-ground basements and half/fully exposed basement walls. I don't know what insulation is behind the drywall, but I plan to reside and if it's still super cold in my basement (God I hope it isn't) I'm going to pull the drywall down and put up foam board. Unfortunately my basement is finished and it's much more work trying to retrofit insulation...
~Coach Dave~ is offline   Reply With Quote
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 07:05 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
insulating basement joan518 Building & Construction 16 11-01-2009 02:06 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
