Insulating Drywalled Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 12:49 PM   #1
insulating drywalled garage
my attached is already drywalled but not taped .I plan on having a heat source to be used occasionally.
Do I need vapor barrier in the ceiling ?
If so should I pull down the existing drywall and start from scratch?
I plan on stripping the walls to insulate the walls properly looking for the right way to tackle the ceiling
thanks Tony
2001flhri is offline   Reply With Quote
Old 04-05-2011, 10:51 PM   #2
Registered User
Rewards Points: 5,516
Welcome to the forum!
Where are you located?
Many times just a v.b. paint primer is added rather than removing material.
Gary
Old 04-09-2011, 06:11 PM   #3
I am located in the valley area of Nova Scotia where we have a variety of weather . The house is a bungalow with an attached garage . There is just attic space above the garage . My concern is if I Insulate it with cellulose do I need to use vapor barrier if I chose to heat the garage on occasion .
With drywall on the ceiling and two garage door openers I'm debating on ripping it all down or just fill the roof trusses with cellulose .
Opinions welcome
Old 04-09-2011, 08:14 PM   #4
Registered User
If you don't need the storage, use cellulose. Anything is better than no insulation. Your area ranges from 3800-4700 H.D.D. It's not a house so the minimum R-value doesn't apply. I'd dense pack the walls and blow-in 2# in attic, no v.b. required; http://www.applegateinsulation.com/C...id=249418&fd=0
http://www.homeenergy.org/archive/he...95/950309.html
Make sure the drywall will support it; http://www.energyguide.com/library/E...SubjectID=8375
http://www.affordablecomfort.org/ima...ck_Handout.pdf
http://www.karg.com/pdf/Presentation...Insulation.pdf
Gary
Old 04-10-2011, 01:05 PM   #5
Thanks for your opinion and advice .
The links are great source of information and education for me . After a little reading I am sure to come up with the best solution for my needs .
Thanks again Tony
Is it worth insulating the garage to help keep the bedroom warm? mitchel General DIY Discussions 10 02-27-2011 09:04 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 12:54 PM
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
