Insulating For Differently Constructed Walls (and Ceiling) - Insulation - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 07:16 PM   #1
Rewards Points: 150
Insulating for differently constructed walls (and ceiling)
I am on the verge of insulating my garage enclosure to office conversion and need some advice. This is not your normal garage enclosure, as I have spent much time and effort on all aspects of this project.
Specifically, I need information regarding a south wall, a small west wall with a window and the ceiling.
Before I get too far into this, a few salient facts:
1. I live in a very hot and humid zone 2 climate (winters are short and mild. Occasional cold winters (just below freezing).
2. Vapor barriers are not required by code.
3. The space will be air-conditioned
4. Outside air will be introduced into the space and conditioned via the return air of the A/C system, so the space will be under a positive pressure. There will be occasional exhaust to the outdoors using the bath ventilator.
5. I have already ordered the insulation. I will be using Roxul rock wool. This insulation has no vapor barrier.
6. All openings and holes in top plates of the space are sealed with either 3M CP 25WB+ Fire Barrier Sealant or (for the bigger openings), Dow Fire Foam. Also, Great stuff Cracks and Gaps for other gaps (not in top plate). Window and door frames will be sealed with Great Stuff for Windows and Doors.
7. (edit): I should also add that all electrical outlets in the space will be sealed against air & sound with putty pads.
South wall facts:
Insulating for differently constructed walls (and ceiling)-southwall_-img_9141.jpg
1. 20’ L x 8’H. Pre-existing brick veneer, black board sheeting (well, brown inside. Black outside…not sure if it’s really BB or what the specs might be). It’s not in great shape.
2. No house wrap on the exterior side of the blackboard
3. Staggered stud wall.
South wall questions:
1. I guess I won’t require a vapor barrier, but I assume that I will need to air seal the wall?
As can be seen in the image, this could be quite a task, depending on what material I use. A foam board is not practical, given the number of cavities, small spaces and obstacles involved, and it would also mean that I lose an inch of space, compacting the Roxul.
I think I could use Tyvek. If so, how? Cut and staple in the stud cavities and spaces? Is some type of brush on sealant required at the staples and seams?
Given my budget, foam in addtion to the Roxul is not really an option, even if I could get someone to take on so small a job.
I am looking to minimize labor without diminishing quality of results. So what is my best option for this wall considering the facts?
West Wall
This is a new 2x6 wall that I built after removing the garage doors:
From outside in, brick, Tyvek, ˝” plyboard. I will be using 5.5” R-23 Roxul.
Am I correct in thinking that just putting in the R-23 Roxul (and again no VB) will do the job for this wall? Top plate gaps and holes are all foamed.
Ceiling:
2x8 joists, 20’x10’. The attic side is decked with ˝” plyboard. I will be placing Roxul 7.5” R-30 insulation.
Will this also be all that is required for the ceiling? I'm assumming there is no need for a VB? The attic is vented with a power ventilator. The soffit vents are covered, but I will be addressing that in the near future.
I will also be placing Styrofoam rafter vents (do these need to be placed at every joist possible, or every “so-many” feet?
Thanks for staying with me so far…any advice is appreciated.
Thanks,
Mark
rightit is offline   Reply With Quote
Old 04-05-2012, 12:42 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,882
South wall facts:
Attachment 48543
I would be ideal to seal that outside wall but more important will be sealing the interior drywall. You have the ability to do both at this juncture so it is preferable.
Easiest thing would be some sort of spray-able sealant of foam. They do make spray-able sealants or you could probably do every part of that area with a 200 board foot kit of foam. You just need to seal the gaps and not cover the entirety of the outside wall.
I wouldn't bother with the Tyvek as it would probably be labor intensive. Look for a spray-able sealant or foam.
You can buy small kits for the small amount you would need.
As stated above.
West Wall
Yes. You do not, nor should you, have a vapor barrier in your climate zone.
Ceiling:
Every joist cavity is proper. Get rid of the powered fan when you fix the soffits and go passive (i.e. ridge vent).
No vapor barrier again. Just make sure the ceiling is air tight. That is exponentially more important in nearly every application as compared to a vapor retarder.
Thanks,
Mark
I think the efforts to seal the outside wall are probably uncessary at the end of the day with the type of insulation you are specifying.
Roxul (mineral wool) is very dense and highly resistant to wind washing and diminished R-Value. Make sure the interior wall is sealed up tight and that will be the more primary seal.
The Following User Says Thank You to Windows on Wash For This Useful Post:
rightit (04-07-2012)
Old 04-05-2012, 04:48 PM   #3
Rewards Points: 150
Hi Windows on Wash. Thanks for the information. The spray foam kits seem to start at around $600. Given that I've gone way over budget on this project (and some of the information you've provided) and still have more to spend, I'm now considering using GS Gaps and Cracks foam to seal up holes, seams and the top and bottoms of the BB (where it meets the top and bottom plates).
Also, I do plan to seal the drywall at edges and seams. Can you (or anyone) suggest a 50 yr. caulk that actually remains flexible? The Sherwin Wms 50 yr caulk I've used just doesn't cut it. It's not 'hard' and cracking, but certainly not soft and flexible as is stated.
Thanks again for the information.
Old 04-05-2012, 06:24 PM   #4
Registered User
Rewards Points: 5,216
I’d caulk the new top plate/old long header joint under the plate to stop any attic vented air from reaching the wall cavities. Also the bottom plate/slab joint – again to stop outside air as it doesn’t appear a poly sill sealer (air/thermal/capillary break) was used under it. Hopefully, poly was used under any new slab…
At the South wall, caulk every cavity at sheathing/stud joint and plate joints, top and bottom- to ceiling/slab to help stop the solar (pressure) drive from wet bricks. It goes right through your blackboard (fiberboard), the caulk will stop any air currents from spreading it to other bays. http://www.buildingscience.com/docum...n-brick-veneer
Add rigid foam board on the stud interior face- air seal and tape/canned foam (top/bottom/seams), then ADA the drywall. http://www.buildingscience.com/docum...wall-approach/
Then your cavity condensation will occur on the inside face of the foam rather than wet/rot/mold the paper-faced drywall. Stop all outside (moist/warm) air from getting inside – over/under/around the exterior frame wall on the inside face (air barrier location). The foamboard changes the condensation (dew point) location—think Thermos bottle. http://www.buildingscience.com/docum...he-humid-south
Requires electrical box extenders or just cut your own from identical new box for foams added thickness. After reviewing all your posts, did you drill weep holes below the soffit, or are there existing ones to the attic- need intake and exhaust to create “rainscreen theory” in the brick wall? There are two types: http://books.google.com/books?id=5Tu...page&q&f=false
For your reading enjoyment:
http://msdssearch.dow.com/PublishedL...romPage=GetDoc
http://www.greenbuildingadvisor.com/...moisture-walls
The rafter vents should be in every bay, for optimal performance. The Roxul should not touch the roof deck to transfer temperatures there, f.b. laid flat is better at the low height of the wall/roof juncture. Incorporate the air baffles using f.b. waste from the walls, rather than buy special: http://www.buildingscience.com/docum...n-roof-venting
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 04-05-2012, 06:28 PM   #5
Of the stuff that you can buy commercially (i.e. Big Blue/Orange) silicons are probably your best along with urethanes.
Old 04-05-2012, 09:00 PM   #6
Rewards Points: 150
Again, Thank you!
Old 04-05-2012, 10:07 PM   #7
Rewards Points: 150
Hi Gary,
Thanks for the links. I’ve read some of these, and the others look to be excellent reading.
Last edited by rightit; 04-07-2012 at 12:12 AM. Reason: (previous content deleted as unnecessary)
Old 04-07-2012, 12:05 AM   #8
Rewards Points: 150
Windows on Wash,
Just wanted to come back with a big thanks for the information you provided. Correct climate based information is very difficult to come by. Due to the huge amount of confusing and contradictary information out there, it's almost a monumental task to get the correct information necessary to do the job right.
Even after reading your response, other information seemed to contradict, and had me scurrying for more information. However, one document that seems to clearly define can be found at Buildingscience.com and is entitled, ironically, "Understanding Vapor Barriers". I post a link for those who might be searching in the future:
http://www.buildingscience.com/docum...iers_r2011.pdf
The image below is an excerpt of the document (pg 10) that describes the vapor barrier for my wall assembly and my climate:
Insulating for differently constructed walls (and ceiling)-vapor-profile.jpg
As you can see, it shows a wall assembly that dries in both directions. The only deviation from that in my case is the lack of house wrap, but additional factors in my favor (as you previously stated) are a higher R-value of insulation (R-13-15 is recommended in contrast to my R-23) and a positive air pressure provided by dehumidified and conditioned outside air. The importance of positive pressure in the space is mentioned in this document excerpt (also buildingscience.com) from page 6 of the below linked pdf:
"The only method of controlling air leakage in the
humid south is controlling air pressure differences across building envelopes and within building cavities. Where problems have occurred, it is because interior conditioned spaces have been at a negative air pressure relative to the exterior and/or building cavities have been at a negative air pressure relative to the exterior"
Link:
http://www.buildingscience.com/docum..._download/file
The information you provided for my zone and circumstances is right on the money, and I can now proceed with confidence that my wall assembly will dry (I will, however, monitor temp and relative humidity in the cavities when finished just to make sure that the cavity behind the brick remains well ventilated and that the positive pressure inside the space exceeds that of the exterior).
Again, thank you!
Mark
search terms: hot, humid, south, brick, vapor barrier, zone 2 climate
Old 04-07-2012, 09:17 AM   #9
Mark,
No sweat. Air loss is always the biggest issue because it carries 100X as much moisture.
Tyvek is so open that it allows drying so that is no worry either.
Bathroom ceiling and walls HELP! Maia Painting 13 02-21-2013 04:21 AM
insulating cathedral ceiling South Branch Ca Building & Construction 1 11-06-2011 08:41 AM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 01:44 PM
New walls, old ceiling with texture... do I tape? rodney23 Drywall & Plaster 12 02-15-2011 11:38 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
