Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-22-2012, 05:43 PM   #1
Insulating crawl space
The video says not to use a vapor barrier. But why can't I first use the plastic strips that fit between the joists up against the floor and then put up the Roxul batts. The vapor barrier is then on the warm side of the insulation.
Cheveldave is offline   Reply With Quote
Old 11-22-2012, 06:13 PM   #2
Moderator
Welcome to the forums! Where are you located?
Gary
Clothes taking longer to dry?
Old 11-25-2012, 12:34 AM   #3
what flooring is above where you propose to install the vb? it better be very vapor open, or you are asking for mold and rot. what is the reason you want the vb, anyway? why not air seal and apply insulation as per buildingscience.com? you will have a vb on the ground, right?
Registers in crawl space? DangerMouse HVAC 9 11-29-2011 09:38 PM
Can I terminate a gas line in a crawl space? czissman Plumbing 7 05-19-2011 12:54 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
