Insulating Corner - Insulation - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 07:24 PM   #1
Rewards Points: 85
Insulating corner
Hello,
I'm currently trying to find a solution to insulate one of the corners of our garage. The wall are framed with 2" x 6" lumber. To insulate one of the tricky corners, I only have about 1" to put the insulation in (see photos below).
I was thinking of going with spray foam. I have a polyurethane spray foam kit but the nozzle won't be able to spray deep enough inside the space. Another option would be to use those spray foam cans but I'm not sure it would work.
Any better solutions ?
westbank is offline   Reply With Quote
Old 10-07-2013, 09:05 PM   #2
Registered User
Rewards Points: 4,936
Drill through both studs (doubled) max. 3-5/16" (60%) as per code, then SPF, Fig.3;http://arch.umd.edu/Tech/Structural_..._Guide_A11.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Fix'n it (10-07-2013)
Tags
corner , insulation , spray foam
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 11:08 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
