Insulating/cooling Attic Space For Storage - Insulation - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 10:31 AM   #1
Insulating/cooling attic space for storage
We live in south Florida. We have just installed kraft faced fiberglass batts installed in attic rafters & wals. There is no roof venting (tile roof). AC air handler is in the attic, and we use the space for storage, so cooing the space is a plus. Electric bills have low despite no previous attic insulation. Question: should we insulate the (to be plywooded) attic floor as well? Segregate it from the house space? It does not have to be as cool as the actual living space. 2nd Question: should we cover the rafter and wall insulation? If so with what? Something easy/simple/cheap would be best. Thanks.
BHCC is offline   Reply With Quote
Old 02-03-2013, 10:47 PM   #2
Registered User
Rewards Points: 4,920
Zone 1, or 2 ???
:http://publicecodes.cyberregs.com/ic..._11_par002.htm
Some background info while you answer; http://www.buildingscience.com/docum...+Humid+Climate
http://www.buildingscience.com/docum...he-humid-south
http://www.buildingscience.com/docum...rchterm=attic+
Gary
excessive moisture in attic crawl space jimmy21 Building & Construction 11 02-19-2012 03:46 AM
Termite/Rats Attic and Crawl Space Vents connor016 Pest Control 4 01-30-2012 05:27 PM
Help...Framing Door Along Slanted Ceiling of Attic Space JDinh1985 Building & Construction 5 09-25-2011 11:50 PM
Attic truss space PrecisionVision Roofing/Siding 0 11-18-2010 11:30 AM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 07:19 AM
