Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-26-2011, 01:20 PM   #1
Question
Insulating concrete room
Not sure if this is the right place (Debating between here and Carpentry)
I have a storage area in the basement that is underneath my concrete patio. Right now it is just a cold room (winter) and since the previous owners plugged the hole/vent to the outside (used to be used as a proper cold room before then), it is just a humid mess in the summer (no water leaking off the walls though, just a humidity smell).
I would like to turn it in to a proper storage area.
Is it possible to frame and insulate that room? How would I go about doing so?
BandE is offline   Reply With Quote
Old 01-29-2011, 12:31 AM   #2
Moderator
Does it have air circulation to it from the basement?
How do you access it?
Is there heat nearby?
Where are you located?
Gary
Clothes taking longer to dry?
Old 05-05-2011, 10:01 AM   #3
So took me a while to respond to this but I am back to thinking about "fixing" this "problem".
Basically the house we purchased has a coldroom attached to the finished basement. It is located under our back patio. It is not insulated at all and the previous owner blocked the vent with some sort of foam. I know there will be a problem in the summer.
The entrance to the room is a simple door that is in the middle of the outside wall of our finished basement. It does not seem to be insulated at all. I had to weather strip the door this winter because the basement was getting really cold because of the draft.
I figure I have 2 options: re-open the vent and hope that is enough to create air circulation (small hole, maybe 5 inches across) or find a way to insulate it like the rest of the basement and turn it into a non-heated storage room.
I would rather option 2 because I feel I am losing a lot of heat because of that room.
Oh and I am in Montreal
Old 05-05-2011, 09:24 PM   #4
Insulation isn't going to make it any warmer unless you put a heater in it. But that sure seems like a waste. I think the foam in the vent is intended for winter only. Take out the foam and let it breathe now that it is warming up. Put it back in November. In the winter, you want that door sealed up tight. In the summer, you might want to crack the door open to get more airflow.
SPS-1 is offline   Reply With Quote
Old 05-05-2011, 10:59 PM   #5
Moderator
I'd use 2" rigid foam board between/under sleepers and drywall for fire Code. Same with the lid. No vapor barrier. http://www.nrc-cnrc.gc.ca/eng/ibp/ir...199/part2.html
Follow local codes.
Gary
Insulating above grade concrete wall jhedger69 Building & Construction 6 07-23-2010 09:06 AM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 01:24 PM
insulating exterior of concrete slab home.. rvegab00 General Discussion 5 10-15-2009 10:26 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 05:04 PM
Insulating Joists over concrete sandyman720 Building & Construction 5 05-24-2007 01:52 PM
