Insulating Cement Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 06:01 PM   #1
Insulating cement wall
Rigid Foam Board, firring strips and drywall?
Marsh is offline   Reply With Quote
Old 10-08-2011, 04:24 PM   #2
I'm new to the boards, but have been doing a lot of research on this for an upcoming project. These are by far the best forums on the web, btw!
Best practice is 2" foam on walls, tape seams well. Cut foam sheets for rim joists and seal well with spray foam.
Standard 2x4 walls are preferred for framing as it allows room for electrical and plumbing and gives you something solid to attach shelves, tv's, etc to.
Bottom plate needs to be pressure treated and even better is to add a sill gasket underneath.
TimMauriello is offline   Reply With Quote
Old 10-12-2011, 10:53 PM   #3
Rewards Points: 956
what if a leak develops behind the foam?
federer is offline   Reply With Quote
Old 10-12-2011, 11:02 PM   #4
concretemasonry's Avatar
Rewards Points: 2,566
If a leak develops, that proves you did not do everything properly before.
Usually due to tie budget or personal reasons/opinions.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Canucker (10-13-2011)
Old 10-12-2011, 11:04 PM   #5
Rewards Points: 956
right. so being human a mistake may have been made causing the leak. so in this case would open cell be better in case of leak? or should the average consumer just get closed cell and hope everything was properly installed?
Old 10-13-2011, 05:44 AM   #6
I'm doing the same thing to my basement. This site was really helpful: http://www.eere.energy.gov/buildings...s/db/35017.pdf
1jumper is offline   Reply With Quote
Insulating old wall without blower? j. pierce Building & Construction 4 03-09-2010 08:56 PM
Cement Wall Repairs muggyfrost Carpentry 2 06-26-2009 01:13 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
