Insulating A Cement Block Home - Insulation - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 07:00 PM   #1
insulating a cement block home
I have a cement block house in Baja, with no insulation. Winter temps range from the 30a at night to the 60a during the day. The house stays very cold all day. How do I insulate it?
cheryl1299 is offline   Reply With Quote
Old 12-24-2011, 07:14 PM   #2
Rewards Points: 960
Does the house have a roof?
Do you have a way to heat the house? What would that be? Fuel source?
Exterior finish? Interior finish?
Single story? Two story?
How are other homes in the area insulated?
You'll probably end up building some 2x4 walls on the inside and putting the insulation in this studded wall. And you'll want to put a cap on it somehow as well.
cleveman is offline   Reply With Quote
Old 12-24-2011, 08:56 PM   #3
Rewards Points: 502
foam sheets covered with stucco would probably be the way I go about insulating the walls.
forresth is offline   Reply With Quote
Old 12-24-2011, 09:04 PM   #4
Rewards Points: 13,732
The cheapest and most DIY way is to add R30 insulation in the attic.
Replacement double pained windows.
Far more expencive and time consuming you can add straping on the inside and or outside and up to 1-1/2 foam on the inside and or outside, add sheetrock over the straping on the inside and add jamb extentions to the window and door opening, on the outside you would have to build out all the window and door trim wrap the trim with aluminum coil stock then add some form of siding.
Old 12-24-2011, 10:16 PM   #5
Registered User
Rewards Points: 5,516
http://www.buildingscience.com/docum...n-brick-veneer
Gary
Tags
blown insulation , cement block walls , hair dryer , leafblower , vacuum
Insulating unfinished basement, First time home owner please help! ashory Building & Construction 7 08-25-2011 11:44 PM
Insulating Older Home splinter2 Building & Construction 4 01-19-2011 09:26 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Insulating above block wall that is above sheetrock klein General DIY Discussions 6 12-11-2008 09:37 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
